Linksys LRT224-UK Wired Dual WAN VPN Router
Quicklinx: 9DY8WS00 Mfr#: LRT224-UK
Type: Router
Connection Type: DSL (Cable)
Standards: Fast Ethernet, Ethernet, Gigabit Ethernet
Rackmount or External: External
£154.59 ex VAT
£185.50 inc VAT
This dual-WAN VPN router can aggregate the bandwidths of both WAN connections to achieve a higher Internet bandwidth than what a single WAN connection can provide. It supports WAN failover, which allows a business to continue its network operation when one of its WAN connections to the Internet fails.
  • Open VPN server support
    Allows to open VPN clients running on employees' laptops, smartphones, and tablets to connect to the offices using two-factory authentication.
  • WAN failover
    Supports WAN failover, which allows a business to continue its network operation when one of its WAN connections to the Internet fails.
  • Dual-wan load balancing
    The dual-WAN VPN router can aggregate the bandwidths of both WAN connections to achieve a higher Internet bandwidth than what a single WAN connection can provide.
  • Integrated firewall
    Supports URL filtering and access rules that allow administrator to further regulate the traffic within the business network based on the services (i.e. TCP/UDP ports) and source/destination IP addresses.
Linksys Business LRT224 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
VPN throughput (IPSec): 110 Mbps , NAT throughput: 900 Mbps
Concurrent connections: 30000
Network / Transport Protocol
PPTP, IPSec, PPPoE, DDNS
Routing Protocol
RIP, static IP routing, RIPng
Remote Management Protocol
SNMP, HTTP, HTTPS
Firewall protection, DMZ port, DHCP support, NAT support, auto-negotiation, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IPv6 support, URL filtering, firmware upgradable, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, DNS proxy, port forwarding, reset button, port triggering, DHCP relay, IPv6-to-IPv4 gateway, tagged VLAN, VPN Server, IGMP proxy, security lock slot (cable lock sold separately)
IEEE 802.1Q, UPnP
19.1 cm x 13 cm x 4 cm
722.2 g
United Kingdom
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
SNMP, HTTP, HTTPS
IEEE 802.1Q, UPnP, FCC Class B certified
Status Indicators
Port status, system, WAN, LAN, DMZ, diagnostic, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
United Kingdom
19.1 cm
13 cm
4 cm
722.2 g
Limited warranty - lifetime
10 - 85% (non-condensing)
9DY8 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9DY8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
9DY8 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Type: Router
Standards: Ethernet
Standards: Gigabit Ethernet
Brand: Linksys
