Ensure high-speed, secure, and reliable network service for employees, whether they're at the office or on the road.
OpenVPN server support
It allows OpenVPN clients running on employees' laptops, smartphones, and tablets to connect to the offices using two-factory authentication. -
Integrated firewall
Supports URL filtering and access rules that allow administrator to further regulate the traffic within the business network based on the services and source/destination IP addresses. -
802.1q support
It provides separation between resources in different SSIDs/VLANs. With inter-VLAN routing, the products allow specified traffic to traverse between VLANs. -
Intuitive web administrative interface
Allows small business owners to deploy and manage the routers without professional IT staff onsite.
- Linksys Business LRT214 - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Performance
- VPN throughput (IPSec): 110 Mbps , NAT throughput: 900 Mbps
- Capacity
- Concurrent connections: 30000
- PPTP, IPSec, PPPoE, DDNS
- Routing Protocol
- RIP, static IP routing, RIPng
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Firewall protection, DMZ port, DHCP support, NAT support, auto-negotiation, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IPv6 support, URL filtering, firmware upgradable, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, DNS proxy, port forwarding, reset button, port triggering, DHCP relay, IPv6-to-IPv4 gateway, tagged VLAN, VPN Server, IGMP proxy, security lock slot (cable lock sold separately)
- IEEE 802.1Q, UPnP
- 19.1 cm x 13 cm x 4 cm
- 722.2 g
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- SNMP, HTTP, HTTPS
- IEEE 802.1Q, UPnP, FCC Class B certified
- Status Indicators
- Port status, system, WAN, LAN, DMZ, diagnostic, VPN
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Localisation
- United Kingdom
- 19.1 cm
- 13 cm
- 4 cm
- 722.2 g
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
