Linksys LNR0208C-UK SMB 2-bay 8 Channel Network Video Recorder
Quicklinx: 9DYKWS00 Mfr#: LNR0208C-UK
The core component of every video surveillance system is the recording unit, and the Linksys 2-Bay Network Video Recorder (NVR) is the perfect balance of price and performance. Protect your business with a reliable record of everything that happens in view of your Linksys cameras.
  • High performance
    Provides maximum throughput up to 150 Mbps.
  • Ample storage
    Stores up to 8 TB total on two internal, hot-swappable 4 TB hard drives. Drive bays are also lockable to protect against theft.
  • Multiple cameras supported
    Records up to eight video feeds simultaneously with eight separate channels.
  • Remote manageability
    Remote live view and remote playback allow you to monitor surveillance feeds from a central location.
Linksys 2-Bay Network Video Recorder - standalone DVR - 8 channels
Standalone DVR - 8 channels - networked
Compression Format
MJPEG, MPEG-4, H.264
Hard Drive(s) Supported
Quantity: 2 - total capacity: 8 TB
11.497 cm x 24.61 cm x 16.494 cm
2 kg
Country Kits
United Kingdom
Standalone DVR
Video Channels
8
Compression Format
Country Kits
United Kingdom
IC, FCC
Security DVR
Record Events
Motion detection
Networked
RAID 0 support, RAID 1 support, JBOD support
Hard Drive
Quantity Supported
2
Serial ATA
Removable
Supported Max Total Capacity
8 TB
Supported Protocols
FTP, SMB, CIFS
Alarm Ports
Alarm input x 4, alarm output x 2
Network Port
10/100/1000Base-T
Other Ports
USB 2.0 x 3, eSATA x 2
11.497 cm
24.61 cm
16.494 cm
2 kg
0 - 95%
9DYK C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
