The core component of every video surveillance system is the recording unit, and the Linksys 2-Bay Network Video Recorder (NVR) is the perfect balance of price and performance. Protect your business with a reliable record of everything that happens in view of your Linksys cameras.
High performance
Provides maximum throughput up to 150 Mbps. -
Ample storage
Stores up to 8 TB total on two internal, hot-swappable 4 TB hard drives. Drive bays are also lockable to protect against theft. -
Multiple cameras supported
Records up to eight video feeds simultaneously with eight separate channels. -
Remote manageability
Remote live view and remote playback allow you to monitor surveillance feeds from a central location.
- Linksys 2-Bay Network Video Recorder - standalone DVR - 8 channels
- Standalone DVR - 8 channels - networked
- Compression Format
- MJPEG, MPEG-4, H.264
- Hard Drive(s) Supported
- Quantity: 2 - total capacity: 8 TB
- 11.497 cm x 24.61 cm x 16.494 cm
- 2 kg
- Country Kits
- United Kingdom
- Standalone DVR
- Video Channels
- 8
- Country Kits
- United Kingdom
- IC, FCC
Security DVR
- Record Events
- Motion detection
- Networked
- RAID 0 support, RAID 1 support, JBOD support
Hard Drive
- Quantity Supported
- 2
- Interface
- Serial ATA
- Removable
- Supported Max Total Capacity
- 8 TB
- Supported Protocols
- FTP, SMB, CIFS
- Alarm Ports
- Alarm input x 4, alarm output x 2
- Network Port
- 10/100/1000Base-T
- Other Ports
- USB 2.0 x 3, eSATA x 2
- 11.497 cm
- 24.61 cm
- 16.494 cm
- 2 kg
- 0 °C
- 40 °C
- 0 - 95%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
