Linksys LGS552-UK 48-Port Managed Switch (2 SPF 10G)
Quicklinx: 9DY2WS00 Mfr#: LGS552-UK
Control and manage your business network with advanced features including layer 2 switching and layer 3 static routing between different VLAN communications without any performance degradation. As a result your network can run more efficiently, as Linksys 500 Series switches will manage internal routing with your router and dedicate fixed paths with external traffic and security. Deliver superior communication via video, voice and data applications over your business network with advanced QoS features. Layer 2 MAC and layer 3 IP flow-based policies and rate limiting control prioritize traffic, offering an ideal solution to manage and control real-time, high bandwidth, voice and video traffic without slowing down your other business applications.
  • Advanced network management capabilities
  • Advanced traffic-handling intelligence
  • Advanced network security features
    Safeguard your business network with extensive Access Control Lists (ACLs) to control and block portions of the network from unauthorized users and external network attacks. Detect and prevent network attacks with DHCP snooping, IP and MAC-port binding functions that ensure network integrity. IEEE 802.1X Port Security strictly limits access to specific segments of your network, while port authentication and MAC-based port security requires clients to authenticate themselves before any data is allowed to pass.
  • Fiber-optic network expansion support
    With an additional Gigabit SFP+ fiber-optic port expansions, Linksys 500 Series Switches provide a powerful combination of business scalability for any server farm and data center environment, and enhances high bandwidth demands while providing redundancy for fast and easy network growth. Mini Gigabit interface converter (mini-GIBC) expansion ports offer you an option to add fiber-optic or Gigabit Ethernet uplink connectivity to these managed switches.
  • Optimal energy-efficient ethernet support
    Reduce energy consumptions by monitoring the amount of traffic and states of any inactive ports without compromising performance. Linksys 500 Series switches are specifically designed to optimize power and efficiency and support the energy-efficient Ethernet (IEEE 802.3az) standards.
Linksys Business LGS552 - switch - 52 ports - Managed - rack-mountable
Switch - 52 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Forwarding performance: 104.16 Mpps , Switching capacity: 140 Gbps
Active VLANs: 1000 , QoS hardware entries: 4
MAC Address Table Size
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, HTTPS, TFTP
DHCP support, ARP support, IGMP snooping, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, static routing, Class of Service (CoS), 802.1x authentication
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3az
AC 100/230 V (50 - 60 Hz)
44 cm x 35 cm x 4.445 cm
4.18 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Authentication Method
RADIUS
RAM
128 MB
Status Indicators
System, link/activity
48 x 1000Base-T RJ-45 , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP , 2 x 10GBase-X SFP+
Internal power supply
United Kingdom
44 cm
35 cm
4.445 cm
4.18 kg
Limited warranty - lifetime
50 °C
10 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
9DY2 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9DY2 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.92
9DY2 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
