Linksys LGS326-UK 24-Port Smart Switch
Quicklinx: 9DXXWS00 Mfr#: LGS326-UK
Type: Gigabit Ethernet
Ports: 26
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£163.57 ex VAT
£196.28 inc VAT
Designed for business-class management, security, speed, and quality of service, Linksys smart PoE+ Gigabit Switches provide a network your business can grow on. Numerous QoS features ensure that traffic is prioritized properly to deliver the best possible user experience for real-time applications like voice and video along with bandwidth-intensive graphic/video file uploads and downloads. IGMP snooping limits IP multicast traffic to the ports that requested it, enabling the rest of the network to operate at peak efficiency.
  • Quality of Service (QoS)
  • Power over Ethernet Plus (PoE+)
    Linksys smart switches support the latest 802.3at (PoE+) standards and provide up to double the power budget per Gigabit Ethernet port while offering 802.3af (PoE) backward compatibility. Power over Ethernet reduces electrical wiring costs, simplifies installation, and supports network devices such as IP cameras and wireless access points in optimal indoor and outdoor locations.
  • Network security
    Unauthorized access to the network and mission-critical data is a constant concern. Linksys smart switches help secure networks through port authentication and MAC-based port security, requiring clients to authenticate themselves before any data is passed. Advanced DHCP snooping and IP-MAC binding functions ensure network integrity and help prevent network attacks.
  • Network expansion
    Linksys smart switches include features for quickly expanding and growing your network. Multiple high-bandwidth trunks between switches enhance availability and redundancy. Spanning Tree Protocol (STP) and storm control features help control planned or inadvertent cable loops, so you can confidently build a mesh of switches and quickly expand your network to support your growing workforce.
Linksys Business Smart LGS326 - switch - 26 ports - Managed - rack-mountable
Switch - 26 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Switching capacity: 52 Gbps , Forwarding performance: 38.69 Mpps
MAC addresses: 8000 , Active VLANs: 128 , QoS hardware entries: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, HTTPS, TFTP
Flow control, DHCP support, VLAN support, IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, DHCP snooping, Quality of Service (QoS), RADIUS support, Jumbo Frames support, LACP support, Port Security, IP-MAC binding, DHCP client, Dynamic VLAN Support (GVRP), Class of Service (CoS), tagged VLAN, 802.1x authentication, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
AC 100/230 V (50/60 Hz)
44 cm x 20 cm x 4.4 cm
2.424 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMPv2, IGMP
Authentication Method
RADIUS
RAM
128 MB
Status Indicators
System, link/activity
26 x 1000Base-T RJ-45 , 2 x SFP
United Kingdom
44 cm
20 cm
4.4 cm
2.424 kg
Limited warranty - lifetime
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 90% (non-condensing)
9DXX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
9DXX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.64
Ports: 26
Managed: Yes
POE: No
Brand: Linksys
