Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed. Power over Ethernet (PoE) capability also carries electrical power to peripheral devices without the need for additional outlets.
Gigabit performance
These unmanaged PoE switches offer Gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference. -
Power where you need it
PoE support lets you deploy network systems such as wireless access, IP telephony, or video surveillance solutions more quickly and at a lower cost, without having to install separate power supplies for individual devices. -
Plug-and-Play convenience
Linksys unmanaged switches offer a quick and easy solution to extend your office network with plug-and-play installation. -
Quality of Service (QoS) traffic prioritization
QoS traffic prioritization gives precedence to particular devices or activities to ensure mission-critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimize speed for each connected device.
 - Linksys Business LGS124P - switch - 24 ports - unmanaged - rack-mountable
 - Switch - 24 ports - unmanaged
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - 12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 120 W
- Performance
 - Bandwidth: 48 Gbps
- MAC Address Table Size
 - 8000 entries
 - Auto-sensing per device, Quality of Service (QoS), DiffServ Code Point (DSCP) support
 - IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
- Power
 - AC 100/230 V (50/60 Hz)
 - 44 cm x 20 cm x 4.4 cm
 - 2.785 kg
- Localisation
 - United Kingdom
 - Limited lifetime warranty
- Enclosure Type
 - Rack-mountable
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 120 W
- Performance
 - 8000 entries
- Status Indicators
 - Port transmission speed, PoE, link/activity
 - 12 x 1000Base-T RJ-45 PoE+ , 12 x 1000Base-T RJ-45
- Power Device
 - Internal power supply
- Voltage Required
 - 17.65 Watt
 - Plug and Play, FCC Class A certified, UL, CB
- Localisation
 - United Kingdom
 - 44 cm
 - 20 cm
 - 4.4 cm
 - 2.785 kg
 - Limited warranty - lifetime
 - 0 °C
 - 50 °C
 - 10 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
                        C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
                        C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
