Linksys LGS105-UK Unmanaged 5-Port switch
Quicklinx: 9DXMWS00 Mfr#: LGS105-UK
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£13.34 ex VAT
£16.00 inc VAT
Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
The unmanaged switch offers Gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
The Linksys unmanaged switch offers a quick and easy solution to extend your office network with plug & play installation.
Power saving features include auto power-down to disable unused ports, smart power for short cable runs, and a port status switch to control LED lights.
  • Efficient power usage
    With an operational power consumption of just 2.01 watts and a standby power consumption of 0.42 watts, this switch is designed for energy efficiency, reducing operational costs and environmental impact.
  • High-speed connectivity
    Equipped with five 10/100/1000 ports, the Linksys Business LGS105 switch supports bandwidths up to 10 Gbps, ensuring high-speed data transfers and efficient handling of traffic, even in busy network environments.
  • Robust environmental tolerance
    Designed to operate in a wide range of temperatures from 0°C to 50°C and to withstand humidity levels from 10 - 90% (non-condensing), this switch is built for reliability in various operating conditions.
  • Plug-and-play simplicity
    Compliant with Plug-and-Play standards, this switch requires no additional configuration, making setup quick and hassle-free, and allowing for immediate integration into existing network infrastructures.
  • Durable and reliable design
    With a MAC address table size of 2000 entries and compliance with multiple IEEE standards, the Linksys Business LGS105 is designed for durability and reliable performance, ensuring long-term operational stability.
Header / Manufacturer
Linksys
Header / Model
LGS105
Networking / Type
Switch
Networking / Form Factor
Desktop
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Ports
5
Header / Packaged Quantity
1
Miscellaneous / Product Colour
Blue
POE
No
Managed
No
Header / Compatibility
PC
Header / Country Kits
United Kingdom
Dimensions & Weight / Height
2.6 cm
Dimensions & Weight / Width
12.1 cm
Dimensions & Weight / Depth
7.5 cm
Service & Support / Type
9DXM C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
Ports: 5
Managed: No
POE: No
Brand: Linksys
