Upgrade the data paths of your local wired network to information superhighways with Gigabit switches at the desktop. Accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed.
The unmanaged switch offers Gigabit speeds to minimize transfer times and greatly enhance the ability to stream high-bandwidth files to connected devices without interference.
The Linksys unmanaged switch offers a quick and easy solution to extend your office network with plug & play installation.
Power saving features include auto power-down to disable unused ports, smart power for short cable runs, and a port status switch to control LED lights.
Efficient power usage
With an operational power consumption of just 2.01 watts and a standby power consumption of 0.42 watts, this switch is designed for energy efficiency, reducing operational costs and environmental impact. -
High-speed connectivity
Equipped with five 10/100/1000 ports, the Linksys Business LGS105 switch supports bandwidths up to 10 Gbps, ensuring high-speed data transfers and efficient handling of traffic, even in busy network environments. -
Robust environmental tolerance
Designed to operate in a wide range of temperatures from 0°C to 50°C and to withstand humidity levels from 10 - 90% (non-condensing), this switch is built for reliability in various operating conditions. -
Plug-and-play simplicity
Compliant with Plug-and-Play standards, this switch requires no additional configuration, making setup quick and hassle-free, and allowing for immediate integration into existing network infrastructures. -
Durable and reliable design
With a MAC address table size of 2000 entries and compliance with multiple IEEE standards, the Linksys Business LGS105 is designed for durability and reliable performance, ensuring long-term operational stability.
- Header / Manufacturer
- Linksys
- Header / Model
- LGS105
- Networking / Type
- Switch
- Networking / Form Factor
- Desktop
- Gigabit Ethernet
- Data Transfer Rate
- 1 Gbps
- Ports
- 5
- Header / Packaged Quantity
- 1
- Miscellaneous / Product Colour
- Blue
- POE
- No
- Managed
- No
- Header / Compatibility
- PC
- Header / Country Kits
- United Kingdom
- Dimensions & Weight / Height
- 2.6 cm
- Dimensions & Weight / Width
- 12.1 cm
- Dimensions & Weight / Depth
- 7.5 cm
- Service & Support / Type
- Limited lifetime warranty
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.76 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.84 |
