Protect your business and enhance your situational awareness with the all-purpose Linksys 1080p 3-magepixel indoor/outdoor 360 mini-dome camera. Inside or outside your business, Linksys network cameras provide superior security, surveillance, and supervision.
- Linksys 1080p 3MP Indoor/Outdoor 360 Mini-Dome Camera - network surveillance camera
- Network surveillance camera - fixed - outdoor, indoor - vandal / waterproof
- Audio
- Yes: built-in microphone
- 400 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 2048 x 1536
- Optical Sensor Type
- CMOS 3 MP
- Minimum Illumination
- 0.1 lux - B&W - F2.0 , 0.5 lux - colour - F2.0
- Focal Length
- 0.98 mm - 1.02 mm
- Ethernet 10Base-T
- Voltage
- PoE
- Motion sensor, Wide Dynamic Range (WDR), SD/SDHC-card slot
- Environmental Parameters (operating)
- -40 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
- Audio Support
- Wired
- 400 g
- Localisation
- United Kingdom
Camera
- Colour - fixed - outdoor, indoor - vandal / waterproof
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 2048 x 1536
- Video Capture
- 2048 x 1536 @ 20 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
- 3 MP CMOS
- Effective Pixels
- 2048 x 1536
Lens Construction
- Focal Length
- 0.98 mm - 1.02 mm
- Horizontal Field of View (degree)
- 182
- Vertical Field of View (degree)
- 182
- Network Interface
- Ethernet 10Base-T
- 1 x network - Ethernet 10Base-T - RJ-45
- FCC, IC Class A, IP67, IK10
- Power Requirements
- PoE
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 10 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
