The Linksys Business Wireless-N Access Point employs Wi-Fi technology (802.11n) to provide a fast, powerful wireless network that's ideal for today's tech-savvy businesses.
Fast transfer rate
It provides high-speed connectivity at transfer rates of up to 300 Mbps for notebooks, smartphones, tablets, and other Wi-Fi enabled devices. With a Gigabit Ethernet port, wireless clients can enjoy the fastest speeds possible by maximizing wireless-to-wired performance. -
Optimal wireless coverage
The Linksys Wireless-N Access Point offers high power for better, wider wireless coverage for you and your business, strengthening your network connection in hard-to-reach areas. -
Flexible deployment
It supports deployment as a traditional access point or set up as a workgroup bridge to extend your wireless range coverage. -
Easy to use
Integrated with 802.3 af/at PoE capability to eliminate external adapters and facilitate optimal placement. -
Advanced security
Protect your network with advanced security features including Rogue AP detection, SSID to VLAN mapping, and 802.1X supplicant.
- Linksys Business LAPN300 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- Maximum number of configured SSIDs: 8 , Virtual interfaces (VLANs): 9
- Power Over Ethernet (PoE) Supported
- PoE+
- 23.698 cm x 24.308 cm x 4.369 cm
- 489.88 g
- Limited lifetime warranty
- 23.698 cm
- 24.308 cm
- 4.369 cm
- 489.88 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- SNMP, HTTP
- Frequency Band
- 2.4 GHz
- Selectable Channels Qty
- 11
- Capacity
- Status Indicators
- System
- Power over Ethernet (PoE), VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Multiple SSID support, PoE+, wireless bridge mode, reset button, 2T2R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication
- Encryption Algorithm
- WPA, WPA2, WEP
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Gain Level
- 1.8 dBi
- 1 x 1000Base-T (PoE+) - RJ-45
- IC, FCC
- PoE+
- Power Device
- External power adapter
- 12.5 Watt
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.76 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
