Linksys dual-band, omni-directional high-gain antennas increase the range of your wireless router, providing enhanced coverage in a horizontal plane. They are latest in the Linksys line of premium products, with each antenna delivering 4dBi in the 2.4GHz band and 7dBi in the 5 GHz band - for up to 2x antenna gain over stock antennas. Easy to install, Linksys high-gain antennas are compatible with any wireless router featuring an RP-SMA connection. Simply detach router's factory antennas and replace with high-gain antennas. These come in two- and four-packs.
- Linksys WRT004ANT - antenna
- Product Type
- Antenna
- Packaged Quantity
- 4 (specifications are for single item)
- 2.6 cm 1 cm
- Length
- 28.8 cm
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Surface mountable, indoor
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- 7 dBi (for 5 GHz), 4 dBi (for 2.4 GHz)
- Directivity
- Omni-directional
- Packaged Quantity
- Product Type
- Antenna
- 2.6 cm
- 1 cm
- Length
- 28.8 cm
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g/n
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- Directivity
- Omni-directional
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 30°
Cabling & Wiring
- Connector Provided
- 1 x RP-SMA
Linksys High Gain Antenna Kit - 4 Pack
