Two computers. One monitor. No Problem. Business professionals who bring home their laptops spend countless evenings in front of a small display and cramped keyboard. Thanks to Switch2 for PC, you can now use your big monitor and full-sized keyboard for both your laptop and home computer. It's simple. Just press the remote to switch your monitor from one computer to the next. Switch2 for PC is also great for connecting your old and new desktop computers, so you can access files and programs effortlessly using the same monitor, keyboard, and mouse.
- Belkin Switch2 for PC USB with Audio - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Users Qty
- 1 local user
- 10.2 cm x 9.5 cm x 2.5 cm
- 369 g
- System Requirements
- Linux, Apple MacOS X 10.0 or later, Microsoft Windows Server 2003, Microsoft Windows 98SE/2000/ME/XP
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 2048 x 1536 @ 65 Hz
- Status Indicators
- Port status
- 2 x VGA HD-15 , 2 x keyboard (USB) / mouse (USB) Type A , 2 x audio mini-jack , 2 x keyboard (USB) / mouse (USB) Type A , 1 x VGA HD-15 , 1 x audio mini-jack
- Included Accessories
- Remote control
- Cables Included
- 1 x keyboard / mouse / video / audio cable - 0.6 m , 1 x keyboard / mouse / video / audio cable - 1.8 m , 1 x remote control cable - 1.8 m
- Software Included
- Drivers & Utilities
- OS Required
- 10.2 cm
- 9.5 cm
- 2.5 cm
- 369 g
- Limited warranty - 3 years
