Linksys EA9500 Tri-Band AC5400 Wi-Fi Router
Quicklinx: C0HJWS00 Mfr#: EA9500-UK
  • IEEE 802.11n
£259.08 ex VAT
£310.89 inc VAT
Capable of filling large homes or offices with Wi-Fi coverage, this router is ideal if your home is filled with people streaming and gaming all at the same time. The eight antennas, beamforming and MU-MIMO support ensure that buffering and lag is kept a minimum – even if you are using the wireless network. Through the QoS or ’media prioritisation’ feature, you can assign bandwidth to certain devices or applications, to further reduce the chance of interruptions. At the core of the router is a 1.4GHz dual-core processor, which provides you with fast file transfers and the ability to send multiple data streams at one time, for faster Wi-Fi speeds to more devices. You can also attach this router to a pre-existing one to use it as an access point or network bridge.
This powerful router has tri-band capabilities, giving it the ability to emit three Wi-Fi signals simultaneously – one 2.4GHz and two 5GHz. You can use the two higher speed 5GHz bands for high-bandwidth applications like video conferencing, movie streaming or gaming without causing a drop in performance and reducing interference. Combined, these three independent Wi-Fi bands can deliver extremely fast transfer speeds of up to 5.3Gbps, which is made up of 1Gbps for 2.4GHz and 2.165Gbps for both 5GHz signals.
Beamforming focuses the Wi-Fi signals to each connected device, providing you with increased signal strength and coverage. Through the use of MU-MIMO technology, each device is treated as if it has its own dedicated router. This way, everyone can enjoy the Wi-Fi connection without interruption or buffering. In particular this router can deliver Wi-Fi to four devices at the same time, thanks to its 4x4 configuration, for stronger, faster performance.
You can connect devices that you want to have direct and stable access to your network, such as game consoles or computers, to one of the four 10/100/1000 Gigabit ports. With the USB 2.0 and USB 3.0 ports, you can even plug in an external storage device to share or quickly transfer its content. You can also share devices such as printers across your Wi-Fi network with these ports. This makes the router act almost like a server, where connected devices can gain access to the files stored on the external device or use the printer, without having to be directly connected.
You can set up and manage your network through the intuitive Linksys Smart Wi-Fi web interface. This gives you the ability to see connected devices, set up and manage guest access and parental controls, manage network traffic and update the firmware without needing to install any software on your computer. The accompanying Linksys Smart Wi-Fi app provides all of these features, so you can manage your network while you’re out and about.
  • Smooth 4K video streaming with blazing-fast Wi-Fi speeds
    The MAX-STREAM AC5400 router offers three independent Wi-Fi bands that deliver extremely fast combined speeds of up to 5.3 Gbps. Tri-Band technology delivers up to double the Wireless-AC performance of a dual-band router. High-bandwidth applications like videoconferencing and movie streaming are ideal for the two high-speed 5 GHz bands, while lower-bandwidth devices like older wireless-N and -G computers can utilize the 2.4 GHz band.
  • Powerful processor for supercharged Wi-Fi
    If you're working in your home office, you can quickly download large files thanks to the MAX-STREAM's 1.4 GHz dual-core processor, which delivers the performance necessary for seamless videoconferencing and fast file transfers. The AC5400 is capable of handling multiple high-speed data streams at once - delivering faster Wi-Fi speeds to more devices.
  • Connect wired devices with USB and Gigabit Ethernet ports
    Eight Gigabit Ethernet ports let you connect an array of wired devices for enhanced file transfer speeds and stability - up to 10x faster than Fast Ethernet. Two USB connections - including one fast USB 3.0 port - are ideal for connecting shared storage devices or printers.
  • Advanced security features for a secure connection
    With the MAX-STREAM AC5400 Router, your work files, data, and home network information are safely connected with WPA/WPA2 encryption and an SPI firewall.
  • High-performance antennas for maximum coverage
    The router features eight adjustable external antennas, which can be positioned for optimal performance. They provide powerful streams of data to your devices, ensuring complete Wi-Fi coverage throughout your home. Unlike the two or three data streams found on other routers, the AC5400 delivers four simultaneous streams for stronger, faster performance.
  • Improved mobile speed and range with beamforming
    Play video games, listen to music, check email, shop, stream movies, and more - without having to worry about signal drop-off. Beamforming technology directs Wi-Fi signals to each of your mobile devices. This focused direction provides increased signal strength and coverage.
Linksys EA9500 - wireless router - Wi-Fi 5 - desktop
Wireless router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Data Transfer Rate
5.3 Gbps
Wi-Fi Protected Setup (WPS), reset button, 4T4R MIMO technology, beamforming technology, Tri-Band
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
26.452 cm x 6.666 cm x 31.815 cm
1.7277 kg
Microsoft Windows 7, Apple MacOS X 10.x or later, Windows 8.1
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Data Transfer Rate
5.3 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC Class B certified
1.4 GHz
Status Indicators
Power, WAN, LAN, wireless, USB, WPS
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
8
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
26.452 cm
6.666 cm
31.815 cm
1.7277 kg
Type: Wireless router
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 5.3Gbps
Brand: Linksys
