The MAX-STREAM AC1900 Multi User-MIMO Router offers two dedicated Wi-Fi bands that deliver combined speeds of up to 1.9 Gbps. Users can manually assign high-bandwidth Wi-Fi activities such as 4K video streaming and online gaming to the high-speed 5 GHz band, while assigning older Wi - Fi devices and activities to the 2.4 GHz band.
MU-MIMO (Multi-User, Multiple-Input, Multiple-Output) technology ensures uninterrupted simultaneous Wi-Fi connections to devices such as HD streaming media players, 4K TVs, tablets, and game consoles. Multiple devices receive high-speed Wi-Fi at the same time and same speed. Your family can access the Internet at the same time without experiencing lag or buffering - at up to 2x the speed of a non-MU-MIMO router.
Enjoy fast-paced Wi-Fi activities such as online multiplayer gaming with the MAX-STREAM AC1900. Powered by a 1.4 GHz dual-core processor, it is capable of handling three simultaneous data streams, delivering improved Wi-Fi performance and faster Wi-Fi speeds to more devices.
Enjoy lag-free streaming with next-gen AC mu-mimo Wi-Fi router
The MAX-STREAM AC1900 Multi User-MIMO Router offers two dedicated Wi-Fi bands that deliver combined speeds of up to 1.9 Gbps. Users can manually assign high-bandwidth Wi-Fi activities such as 4K video streaming and online gaming to the high-speed 5 GHz band, while assigning older Wi - Fi devices and activities to the 2.4 GHz band. -
Endless Wi-Fi entertainment in busy homes
MU-MIMO (Multi-User, Multiple-Input, Multiple-Output) technology ensures uninterrupted simultaneous Wi-Fi connections to devices such as HD streaming media players, 4K TVs, tablets, and game consoles. Multiple devices receive high-speed Wi-Fi at the same time and same speed. Your family can access the Internet at the same time without experiencing lag or buffering - at up to 2x the speed of a non-MU-MIMO router. -
Lag-free online gaming via powerful processor
Enjoy fast-paced Wi-Fi activities such as online multiplayer gaming with the MAX-STREAM AC1900. Powered by a 1.4 GHz dual-core processor, it is capable of handling three simultaneous data streams, delivering improved Wi-Fi performance and faster Wi-Fi speeds to more devices. -
High-speed wired connectivity with Gigabit Ethernet ports
Connect more devices and share files at speeds 10x faster than Fast Ethernet with four Gigabit Ethernet ports. Connect a storage device and quickly transfer files or share devices such as printers across your Wi-Fi network using the USB 2.0 and USB 3.0 ports. -
Improved Wi-Fi speed and range with beamforming
Direct Wi-Fi signals to each of your mobile devices to increase signal strength and coverage with our MAX-STREAM Wi-Fi router using Beamforming technology. Play video games, listen to music, check emails, shop online, stream HD movies, and more, without having to worry about dropped signals.
- Linksys EA7500 - wireless router - 802.11a/b/g/n/ac - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.9 Gbps
- Reset button, 3T3R MIMO technology, beamforming technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 25.7 cm x 5.6 cm x 18.4 cm
- 558 g
- System Requirements
- Microsoft Windows 7, Apple MacOS X 10.x or later, Windows 8.1
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.9 Gbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, 128-bit AES, WPA2-Enterprise
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, FCC Class B certified
- Processor
- 1.4 GHz
- Status Indicators
- WAN, LAN
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 25.7 cm
- 5.6 cm
- 18.4 cm
- 558 g
