The Linksys EA6900 AC1900 Simultaneous Dual-Band Broadband Wireless-AC Router is designed to take your wireless network to the next level with the latest in wireless technology. Using the latest Draft 802.11ac Wireless Technology the Linksys EA6900 is capable of speeds up to 600Mbps + 1300Mbps. Packed full with features, the Linksys provides ultimate wireless range due to high power amplifiers and SpeedBoost technology. With Connect Cloud, the Linksys EA6900 allows you to access your home network from anywhere, making this Linksys Smart Wi-Fi Router the future for home networking.
Key Features
Latest 802.11ac Wireless-AC Technology*
Backward Compatible with a/b/g/n Devices
Ultimate Speeds - Up to 600 + 1300 Mbps*
High Power Amplifiers for Ultimate Range*
SpeedBoost Technology for Increased Signal Strength
WPA2 Encryption and SPI Firewall and IPv6 Enabled
Four 10/100/1000 Gigabit Ethernet Ports
2 USB Ports to Simultaneously Share Printers and Storage**
3D Antenna Array Allows for Wall Mounted or Table Top Display
DLNA Certified Media Server for video streaming
Quality of Service (QoS) for Smoother HD Video
SimpleTap Technology-Add Wi-Fi Devices to Your Network
Connect Cloud
Now available for Linksys EA6900 and other Smart Wi-Fi Routers in the series, Connect Cloud gives you anytime, anywhere access to your home network. This revolutionary new technology delivers a host of free apps for your router, and that's only the beginning. As new devices and ways of interacting with your home emerge, Connect Cloud will keep expanding with new apps to enrich your connected lifestyle.
Create your wireless home network: Linksys Smart Wi-Fi Routers make it fast and easy.
Register your network online: Go to CiscoConnectCloud.com to open your account.
Customise with apps: Enhance your connected home with the apps of your choice.
Building the Future Together
As the world networking leader, Linksys is partnering with cutting edge appliance and device manufacturers to build the smart home of tomorrow. In that home, you will experience easier living through a variety of smart devices that will be connected to your home network. As more and more apps are released for Linksys Smart Wi-Fi Routers, it will become the key to running tomorrow's connected home.
Wireless AC technology
The Linksys EA6900 uses the next generation Wireless AC technology for powerful networking. -
Dual band 2.4+5 GHz
Double the bandwidth to maximize wireless throughput. -
Beamforming technology
Focuses wireless signal from router to the client device for optimal performance. -
USB ports
Add external storage or other devices to share across your network. USB 3.0 transfer rate is 10x faster than USB 2.0. -
DLNA certified media server
Easily search for and play media (video, music, images) across your network. -
Advanced security
Wireless WPA/WPA2 encryption and SPI firewall help keep your network safely connected. -
Guest access
Easily secure your network while providing guests with Wi-Fi access. -
Easy setup
Simple installation, no CD required. -
Parental controls
Easily manage access to Internet by device with ability to create schedule and specific websites. Monitor at home or while away with Smart Wi-Fi using your computer browser or smartphone. -
Linksys smart Wi-Fi
Enhanced wireless router web interface. Monitor and control your home network from anywhere using computer browser or smartphone. -
Device priority quality of service
Wi-Fi traffic prioritization for smooth HD video performance. -
Adjustable external antennas
Adjust antennas for optimal wireless Wi-Fi performance.
- Linksys EA6900 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
- Frequency Band
- 2.4 GHz / 5 GHz
- Stateful Packet Inspection (SPI), IPv6 support, parental control, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, DLNA Media Server, 3T3R MIMO technology, SimpleTap technology
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
- 25.62 cm x 4.01 cm x 18.45 cm
- 534 g
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5.8 or later, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 or later, Windows 8
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Encryption Algorithm
- WPA, WPA2, WEP
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), ICES-003, RSS-210, FCC, WEEE, LVD
- Status Indicators
- Power, WAN, LAN, WPS
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , USB 2.0: 1 x 4 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- OS Required
- 25.62 cm
- 4.01 cm
- 18.45 cm
- 534 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.08 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £19.26 |
