Linksys EA6350-UK
Linksys EA6350-UK
Quicklinx: 9XFGWS00 Mfr#: EA6350-UK
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 1200Mbps
Rackmount or External: External
  • IEEE 802.11n
More than 50 in stock
£79.35 ex VAT
£95.22 inc VAT
The Linksys EA6350 Smart AC1200 Simultaneous Dual-Band WiFi Broadband Router features high-speed Wireless-AC technology and Smart Wi-Fi software to deliver next-generation home network performance. Engineered for the well-connected household, this Linksys EA6350 WiFi Router brings next-generation wireless speed to all your devices. This Linksys EA6350 WiFi Router also comes equipped with Smart Wi-Fi software, allowing users to monitor and control their home network from anywhere, anytime, using a smartphone.
Next-generation wireless
This Linksys EA6350 Smart AC1200 Simultaneous Dual-Band WiFi Broadband Router brings next-generation wireless speed to all your devices. Featuring USB 3.0 and four Gigabit ports along with the latest Wireless-AC technology, this Linksys EA6350 is optimised to support all wired and Wi-Fi devices. Leveraging dual bands with up to N300 Mbps + AC867 Mbps, data traffic can flow quickly and with minimal buffering - meaning gaming, media streaming and general Internet activities can occur simultaneously with no interruptions.
This Linksys EA6350 WiFi Router comes equipped with Smart Wi-Fi software, allowing users to monitor and control their home network from anywhere, anytime, using a smartphone. The Smart Wi-Fi feature allows users to see what devices are on the network, block devices from Internet access or specific websites, create a password-protected guest network and more.
Key features
Up to 2.8 times faster than Wireless-N technology: Simultaneous dual-band speed up to N300 Mbps (2.4 GHz) + AC867 Mbps (5 GHz) for media-intense applications
USB 3.0 port: USB 3.0 and Gigabit Ethernet ports ensure ultimate media streaming and fast data transfer of photos, video, data files or connecting devices across your network. USB 3.0 is 10 times faster than USB 2.0.
Linksys Smart Wi-Fi: Monitor and control a home network from anywhere and at any time. Smart Wi-Fi allows users to prioritise devices or websites, gain parental control over inappropriate content, monitor network activity, turn Wi-Fi access on or off,and create select password-protected guest networks.
Smart Wi-Fi apps: A growing suite of apps offers improved opportunities to control one's home network
Easy setup: Simple installation and requires no CD
Linksys EA6350 - wireless router - 802.11a/b/g/n/ac (draft) - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft)
Frequency Band
2.4 GHz / 5 GHz
IPv6 support, parental control, firmware upgradable, RADIUS support, Wi-Fi Protected Setup (WPS), reset button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft)
25.6 cm x 18.4 cm x 4 cm
501 g
Microsoft Windows 7, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later, Apple MacOS X 10.6.1 or later, Apple MacOS X 10.7 Lion, Windows 8, Apple OS X 10.8 Mountain Lion
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, WEP
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, DLNA CERTIFIED, UPnP, IEEE 802.11ac (draft), IC, FCC
Status Indicators
Power, WAN, LAN, WPS
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
External power adapter
1 x network cable
United Kingdom
25.6 cm
18.4 cm
4 cm
501 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 - 80% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac (draft)
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 1200Mbps
Brand: Linksys
Price Range Ex VAT: 50 - 100
