Linksys Business AC2600 Dual-Band Cloud AC Wave 2 Radio Access Point
Quicklinx: FD88WS00 Mfr#: LAPAC2600C-EU
  • IEEE 802.11n
£182.28 ex VAT
£218.73 inc VAT
The Linksys Business Dual-Band AC Wave 2 Wireless Access Points include Cloud Manager, a cloud-hosted Wi-Fi Management Platform purpose-built for small business environments that helps reduce costs and increase efficiencies.
  • Cloud manager
    The intuitive and easy to use browser-based dashboard provides remote access to your Linksys access points, centralized visibility with real-time monitoring to manage single or multiple site networks, and a simple single sign-on.
  • Next generation AC Wi-Fi connectivity
    Allows multiple clients to transmit data simultaneously, improving performance and productivity in high density wireless environments. Features 4 x 4 Dual-Band (2.4+5 GHz) AC delivering combined speeds of up to 2.53 Gbps* for faster, more robust wireless performance.
  • Flexible deployment
    Zero-Touch provisioning allows for faster deployment of Linksys access points without having to be on-site.
  • Centralized management
    Cloud Manager has a centralized management platform, allowing you to manage multiple sites from a single pane of glass.
  • Easy to use
    The easy to use browser-based cloud interface is accessible from any location through the internet and from a single login.
  • Captive portal
    Secure and customized guest Wi-Fi access. The captive portal is also used at many Wi-Fi hotspots to control wireless access in the area.
  • Power over Ethernet integrated
    Integrated with 802.3at PoE+ capability to eliminate extra power adapters and offer optimal placement.
  • Advanced security over wireless
    Protects and secures your wireless network with business class security features including Wi-Fi Protected Access (WPA/WPA2), Rogue AP Detection, SSID-to-VLAN Mapping, Wireless Scheduler, and more.
Linksys Business AC2600 Dual-Band Cloud AC Wave 2 - radio access point - Wi-Fi 5 - cloud-managed
Radio access point
Wall / ceiling mountable
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
Power Over Ethernet (PoE) Supported
PoE+
23.7 cm x 24.3 cm x 4.369 cm
848 g
Radio access point
23.7 cm
24.3 cm
4.369 cm
848 g
Europe
Wireless
Data Transfer Rate
2.53 Gbps
Routing Protocol
IGMP, MLD
Remote Management Protocol
SNMP, HTTP, HTTPS
Cloud-Managed
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
IGMP snooping, Syslog support, DiffServ support, IPv6 support, Wireless Distribution System (WDS) support, Media Bandwidth Management (MBM), Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, wireless bridge mode, reset button, clustering technology, Link Aggregation Control Protocol (LACP), rogue access point detection, e-mail notification, 4T4R MIMO technology, Captive Portal, security lock slot (cable lock sold separately), 802.1x authentication, MU-MIMO technology, scheduler, band steering, event notification, network diagnostics, SSID to VLAN mapping, dual image support
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.11k, IEEE 802.3at, IEEE 802.11r
Aerial
Antenna
Internal
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (management) - RJ-45
1 x network cable
IC, FCC
PoE+
External power adapter
25 Watt
Limited warranty - lifetime
10 - 85% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 2.53Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Brand: Linksys
