Linksys Business AC1750 Dual-Band Cloud Radio Access Point
Quicklinx: FD86WS00 Mfr#: LAPAC1750C-EU
  • IEEE 802.11n
£138.16 ex VAT
£165.79 inc VAT
The Linksys LAPAC1750C Wireless Cloud Access Point delivers wireless data transfer rates of up to 1.7 Gbps and includes Linksys Cloud Manager, the web-based Wi-Fi Network Management solution. Cloud Manager lets you remotely manage multiple networks, Access Points and sites from one centralized and easy-to-use dashboard that's accessible anytime, from any device. Cloud Manager will alert you to any network problems. You can access it from any computer, tablet or mobile phone and easily get real time statistics on the health of your network. The Linksys LAPAC1750C can be set to adopt the configuration of other Access Points and can be pre-configured before it is turned on for Rapid Deployment. A 5-year Linksys Cloud Manager license is included at no additional cost. When it expires, you can choose to purchase the license for an additional five years.
  • Cloud Manager
    The intuitive and easy to use browser-based dashboard provides remote access to your Linksys access points, centralized visibility with real-time monitoring to manage single or multiple site networks, and a simple single sign-on.
  • Next-generation Wi-Fi connectivity
    Leverages Wireless-AC technology to ensure faster Wi-Fi speeds and increased productivity for your entire office.
  • Flexible deployment
    Zero-Touch provisioning allows for faster deployment of Linksys access points without having to be on-site.
  • Centralized management
    Cloud Manager has a centralized management platform, allowing you to manage multiple sites from a single pane of glass.
  • Easy to use
    The easy to use browser-based cloud interface is accessible from any location through the Internet and from a single login.
  • Captive portal
    Secure and customized guest Wi-Fi access. The captive portal is also used at many Wi-Fi hotspots to control wireless access in the area.
  • Power over Ethernet integrated
    Integrated with 802.3at PoE+ capability to eliminate extra power adapters and offer optimal placement.
  • Advanced security over wireless
    Protects and secures your wireless network with business class security features including Wi-Fi Protected Access (WPA/WPA2), Rogue AP Detection, SSID-to-VLAN Mapping, Wireless Scheduler, and more.
Linksys Business AC1750 Dual-Band Cloud - radio access point
Radio access point
Wall / ceiling mountable
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16 , Virtual interfaces (VLANs): 17
Power Over Ethernet (PoE) Supported
PoE+
23.698 cm x 24.308 cm x 4.369 cm
508 g
Radio access point
23.698 cm
24.308 cm
4.369 cm
508 g
Europe
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
SNMP, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System
VLAN support, Syslog support, E-mail alert, MAC address filtering, IPv6 support, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Multiple SSID support, PoE+, wireless bridge mode, reset button, 3T3R MIMO technology, rogue access point detection, ceiling mountable, security lock slot (cable lock sold separately), 802.1x authentication, cloud managed, workgroup bridge, channel isolation, scheduler, band steering, event notification, network diagnostics, SSID to VLAN mapping, rate limit, dual band
Encryption Algorithm
AES, PEAP, TKIP, WPA, WPA2, WEP
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
1 x 1000Base-T (PoE+) - RJ-45
IC, FCC
PoE+
External power adapter
15 Watt
Limited warranty - lifetime
10 - 85% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: Linksys
Price Range Ex VAT: 100 - 150
