Built with leading 802.11n wireless technology, the Linksys AE1200 offers expanded coverage and reliability. MIMO (multiple input multiple output) antennas boost signal strength so you can stay connected whether at home or at Wi-Fi hotspots on the go.
Keep Wi-Fi freeloaders and Internet threats at bay with the latest in WPA2 security to help keep your network protected. The included setup wizard installs your adapter quickly and makes going wireless easy.
Upgrade your computer with the freedom and reliability of Wireless-N. Just plug the USB Adapter into your computer to wirelessly connect to your network. With transfer rates up to 300 Mbps you'll enjoy a powerful networking experience for surfing, chatting, sharing or playing online.
High speed
Upgrade your computer with the freedom and reliability of Wireless-N. Just plug the USB Adapter into your computer to wirelessly connect to your network. With transfer rates up to 300 Mbps you'll enjoy a powerful networking experience for surfing, chatting, sharing or playing online. -
Quick to install
Set up your adapter in a few quick steps with a simple setup wizard. -
Extended wireless range
Built with leading 802.11n wireless technology, the Linksys AE1200 offers expanded coverage and reliability. MIMO (multiple input multiple output) antennas boost signal strength so you can stay connected whether at home or at Wi-Fi hotspots on the go. -
Advanced security
Keep Wi-Fi freeloaders and Internet threats at bay with the latest in WPA2 security to help keep your network protected. -
Easy setup
- Linksys AE1200 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 7.3 cm x 2.4 cm x 0.9 cm
- 11 g
- Localisation
- Europe
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Localisation
- Europe
- Connectivity Technology
- Wireless
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, 16 QAM
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- MIMO technology, RADIUS support
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- UL, C-Tick, IC, FCC, RoHS, WEEE
- Software Included
- Drivers & Utilities
- OS Required
- 7.3 cm
- 2.4 cm
- 0.9 cm
- 11 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
