Linksys AE1200 Wireless N USB Adapter
Quicklinx: 8SDYWS00 Mfr#: AE1200-EU
  • IEEE 802.11n
Built with leading 802.11n wireless technology, the Linksys AE1200 offers expanded coverage and reliability. MIMO (multiple input multiple output) antennas boost signal strength so you can stay connected whether at home or at Wi-Fi hotspots on the go.
Keep Wi-Fi freeloaders and Internet threats at bay with the latest in WPA2 security to help keep your network protected. The included setup wizard installs your adapter quickly and makes going wireless easy.
Upgrade your computer with the freedom and reliability of Wireless-N. Just plug the USB Adapter into your computer to wirelessly connect to your network. With transfer rates up to 300 Mbps you'll enjoy a powerful networking experience for surfing, chatting, sharing or playing online.
  • High speed
  • Quick to install
    Set up your adapter in a few quick steps with a simple setup wizard.
  • Extended wireless range
  • Advanced security
  • Easy setup
Linksys AE1200 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
7.3 cm x 2.4 cm x 0.9 cm
11 g
Europe
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3
Network adapter
External
USB 2.0
Europe
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, 16 QAM
Frequency Band
2.4 GHz
Status Indicators
Link/activity
MIMO technology, RADIUS support
Aerial
Antenna
Internal
Antenna Qty
2
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
UL, C-Tick, IC, FCC, RoHS, WEEE
Software Included
Drivers & Utilities
7.3 cm
2.4 cm
0.9 cm
11 g
10 - 85% (non-condensing)
