Linksys Advanced Secure Ultra High Def KVM Switch 4-Port Plus
Quicklinx: FD84WS00 Mfr#: F1DN104P-3ea
DisplayPort is a complex protocol with the capabilities of transferring various types of information beyond just display signals, therefore challenging in terms of security. In 2014, Belkin was the first to introduce Common Criteria products in the market which supported DisplayPort systems and is now offering the latest Belkn Advanced Secure Ultra High Definition KVM, the latest addition to the Belkin secure line up is the perfect solution for applications that require high resolution support. The Belkin Advanced Secure Ultra High Def KVM is fully compatible with computer systems using video cards with 1.1 and 1.2 DisplayPort protocols; supporting resolutions up to 3840 x 2160. True data path isolation for workstations in a highly secure environment provides the ultimate secure solution for government agencies. The KVM is designed, manufactured and certified to the NIAP Protection Profile Ver.3.0 standard. The NIAP Protection Profile ensures agencies are receiving the appropriate security for Keyboard and Pointing Devices, superior protection for HDMI displays and improved audio device security.
  • Dedicated processors with emulators for every port
    Isolated port paths for video and audio to prevent data leaks between computers.
  • Unidirectional data paths
    Optical data diodes prevent peripherals from being used to breach systems.
  • Display security
    Protected display interface prevents data leakage via the monitor.
  • Peripheral management
    USB device detection prevents unauthorized peripheral usage.
  • Anti-tampering
    Internal electrical sensors render unit inoperable if opened.
  • Secure labeling
    Holographic tamper-evident product label provides visual indication and prevention of tampering.
  • Fast switching
    No keyboard or mouse delays when switching ports.
  • High retention connectors
    Semi-locking USB ports prevent accidental disconnection.
  • Uni-body chassis
    Minimizes entry points and prevents physical tampering.
  • Customizable port coloring and naming
    Facilitates port identification and reduces user switching errors.
  • Easy mounting
    Uses an integrated mounting track to allow under-desk or side-wall mounting, creating extra desk space.
  • Secure packaging
    Tamper-evident packaging ensures product is not tampered with during transport.
Belkin Advanced Secure UHD Single-Head DisplayPort KVM Switch with CAC Port - KVM / audio switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio
KVM Users Qty
1 local user
CAC reader support
AC 120/230 V
31.75 cm x 15.75 cm x 4.83 cm
1.77 kg
Red Hat Linux, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
3840 x 2160 @ 30 Hz
CAC reader support, single-head
Status Indicators
Port status
4 x DisplayPort input , 1 x HDMI output , 8 x keyboard (USB) / mouse (USB) Type B , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 4 x audio input mini-jack , 1 x USB 3.0 Type A , 1 x audio output mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
External power adapter
AC 120/230 V
FCC Class B certified, UL, RoHS, ICES, EAL 2+
31.75 cm
15.75 cm
4.83 cm
1.77 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
