DisplayPort is a complex protocol with the capabilities of transferring various types of information beyond just display signals, therefore challenging in terms of security. In 2014, Belkin was the first to introduce Common Criteria products in the market which supported DisplayPort systems and is now offering the latest Belkn Advanced Secure Ultra High Definition KVM, the latest addition to the Belkin secure line up is the perfect solution for applications that require high resolution support. The Belkin Advanced Secure Ultra High Def KVM is fully compatible with computer systems using video cards with 1.1 and 1.2 DisplayPort protocols; supporting resolutions up to 3840 x 2160. True data path isolation for workstations in a highly secure environment provides the ultimate secure solution for government agencies. The KVM is designed, manufactured and certified to the NIAP Protection Profile Ver.3.0 standard. The NIAP Protection Profile ensures agencies are receiving the appropriate security for Keyboard and Pointing Devices, superior protection for HDMI displays and improved audio device security.
                Dedicated processors with emulators for every portIsolated port paths for video and audio to prevent data leaks between computers.
                Unidirectional data pathsOptical data diodes prevent peripherals from being used to breach systems.
                Display securityProtected display interface prevents data leakage via the monitor.
                Peripheral managementUSB device detection prevents unauthorized peripheral usage.
                Anti-tamperingInternal electrical sensors render unit inoperable if opened.
                Secure labelingHolographic tamper-evident product label provides visual indication and prevention of tampering.
                Fast switchingNo keyboard or mouse delays when switching ports.
                High retention connectorsSemi-locking USB ports prevent accidental disconnection.
                Uni-body chassisMinimizes entry points and prevents physical tampering.
                Customizable port coloring and namingFacilitates port identification and reduces user switching errors.
                Easy mountingUses an integrated mounting track to allow under-desk or side-wall mounting, creating extra desk space.
                Secure packagingTamper-evident packaging ensures product is not tampered with during transport.
- Belkin Advanced Secure UHD Single-Head DisplayPort KVM Switch with CAC Port - KVM / audio switch - 4 ports
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Users Qty
- 1 local user
- CAC reader support
- Power
- AC 120/230 V
- 31.75 cm x 15.75 cm x 4.83 cm
- 1.77 kg
- System Requirements
- Red Hat Linux, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 4 x KVM / audio
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2, USB
- Max Resolution
- 3840 x 2160 @ 30 Hz
- CAC reader support, single-head
- Status Indicators
- Port status
- 4 x DisplayPort input , 1 x HDMI output , 8 x keyboard (USB) / mouse (USB) Type B , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 4 x audio input mini-jack , 1 x USB 3.0 Type A , 1 x audio output mini-jack , 2 x keyboard (USB) / mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- FCC Class B certified, UL, RoHS, ICES, EAL 2+
- OS Required
- 31.75 cm
- 15.75 cm
- 4.83 cm
- 1.77 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
