IT administrators responsible for installations are often understaffed and overworked, and many operate within the confines of a strict budget. In order to service their systems, these administrators have often relied on large, less-efficient consoles with limited features, cumbersome configurations, and difficult installation processes. The Belkin 18.5-inch Widescreen Rack Console offers an innovative new design that simplifies your IT duties at every turn. The often-cumbersome installation process has been reduced to a hassle-free, one-person job - simply slide it in, and you're done. Belkin 18.5-inch Widescreen Rack Consoles are lighter and slimmer than ever before, and deliver simplified deployment, instant access, and reduced energy usage. And with the ultra-slim 18.5-inch widescreen display, you'll enjoy a more comfortable viewing area while saving valuable rack space. Belkin 18.5-inch Widescreen Rack Consoles are just another way Belkin enables you to successfully simplify your IT responsibilities.
- Belkin Widescreen Rack Console - KVM console - 18.5"
- KVM Switch
- PS/2, USB - 8 ports
- Keyboard, touchpad, keypad
- Native Resolution
- 1366 x 768 at 65 Hz
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V (50/60 Hz)
- 48.3 cm x 69.9 cm x 4.32 cm
- Height (Rack Units)
- 1U
- 11.3 kg
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 18.5"
- Native Resolution
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- 1U
- 11.3 kg
Input
KVM
- 8 ports
- Keyboard / Mouse Interface
- PS/2, USB
- VGA , Keyboard (PS/2) , Mouse (PS/2) , Stacking (DB-25) , 2 x USB , Management (RJ-11) , 8 x KVM (50 pin Centronics)
- Rack Mounting Kit
- Included
- Input Voltage
- OS Required
- Novell NetWare 5.x, Microsoft Windows Server 2003, Apple MacOS X or later, Red Hat Linux 8.x, SunSoft Solaris 8 or later, Microsoft Windows 95/98/ME/NT/2000/XP/Vista/7/8/10
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
