Pack of 10 locks (without key). 5 different color code versions available. Each key only works with a lock of the same color.
Effective security solution
Blocking unused USB ports helps mitigate the risk of data breaches and unauthorized device connections, allowing for safer computing environments. -
Convenient packaging
The pack of 10 locks provides ample supply for various devices, making it easy to secure multiple ports without the hassle of purchasing additional items.
- Lindy USB Port Blocker - USB port blocker
- Product Type
- USB port blocker
- Packaged Quantity
- 10 (specifications are for single item)
- Package Content
- 10 locks (without key)
- Blue
- Packaged Quantity
- Product Type
- USB port blocker
- Package Content
- Blue
Interface Provided
- Connector Provided
- 4 pin USB Type A x 1
