Lindy 5m USB 2.0 Slimline Active Extension Cable
Quicklinx: CK5CWS00 Mfr#: 42817
Length: 5m
Hurry, only 3 left in stock!
£13.81 ex VAT
£16.57 inc VAT
The simple and affordable USB extender features USB 2.0 active extension repeater lead. Plug and Play - no special software installation required. Compatible with both USB 2.0 and USB 1.1 devices. For even greater distances simply connect up to 5 cables in series. The USB Active Extension System can support distances of up to 56m.
The LINDY USB Extension Cable uses built-in active electronics to extend the cable length of a USB 2.0 device by an additional 5m. Up to 5 extension cables can be chained together to achieve a distance of 25m. The cable's unique, slimline design allows the active electronics to fitted into a standard USB connector - an advantage over other active USB leads which use special, bulky connectors.
  • Reliable connectivity
    This USB extension cable maintains a consistent data transfer rate, ensuring that devices communicate effectively over longer distances.
  • User-friendly design
    With a male 4-pin USB Type-A connector on one end and a female 4-pin USB Type-A connector on the other, this cable is easy to connect and disconnect for hassle-free use.
Lindy USB 2.0 Slimline Active Extension Cable - USB extension cable - USB to USB - 5 m
USB extension cable
Length
5 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB extension cable
Length
5 m
Connector
Length: 5m
Brand: Lindy
