Create an atmousphere with the LightwaveRF 1 Gang 250W Master Hard Wired On/Off Dimmer
The 1 gang dimmer switches can be installed into existing wall socket box
Master switches are one way switches, to use on a two way circuit, add a slave switch at the other end of the circuit
This can be controlled by PC or smartphone when used with the WIFI link controller
1 Gang 240 Volt 250WFits standard wall socket box 433.9 Mhz
Flush mounted
Download LightwaverRF APP from your APP store
Dimension: 88x88x30mm HxWxD
Satin Steel
- LightwaveRF Connect Series LW201 - switch - stainless steel
- Product Type
- Switch
- Functions
- Switching
- Power Source
- Battery
- Connectivity
- Wireless
- Frequency Band
- 433.92 MHz
- Input Type
- 2 buttons
- Stainless steel
- Finish
- Stainless steel coating
- 2-year warranty
- 8.8 cm x 1.4 cm x 8.8 cm
- Product Type
- Switch
- Functions
- Switching
- Power Source
- Battery
- Lamp Compatibility
- Incandescent lamp, halogen lamp, dimmable LED lamp
- Connectivity Technology
- Wireless
- Max Range Indoors
- 15 m
- Frequency Band
- 433.92 MHz
- Wall mountable, 1 channel, 1-gang, remote access, LED indicator, 2 buttons
Control Unit
- Buttons Qty
- 2
- Form Factor
- CR2032
- Required Qty
- 1
- Stainless steel
- Finish
- Warranty
- 2-year warranty
- Directive 93/68/EEC, EN 61000-3-3:2008, EN 61000-4-2:2009, EN 61000-4-5:2006, EN 61000-4-6:2009, EN 61000-4-11:2004, LVD 2006/95/EC, EN 61000-4-3:2006+A1:2008+A2:2010, EN 55022:2010, EN 301 489-1 V1.9.2 (2011-09), R&TTE Directive 1999/5/EC, EN 61000-3-2:2006+A1:2009+A2:2009 Class A, EN 301 489-3 V1.4.1:2002, EMC 2004/108/EEC, EN 60730-1, EN 61000-4-4:2012, EN 300 220-1 V2.1.1:2006, EN 300 220-2 V2.1.2:2007
- 8.8 cm
- 1.4 cm
- 8.8 cm
- 78 g
