Modern & sleek LightwaveRF White 1 Gang 2-Way Dimmer
1 Gang 2 Way dimmer works exactly the same as a standard dimmer
The switches can be controlled by any LightwaveRF device
Simple to install uses existing wiring, set any type of mood in your home and save the settings so you can recall at your pleasure
This can be controlled by PC or smartphone when used with the WIFI link controller
3V CR2032 lithium battery included
Surface mounted
Download LightwaverRF APP from your APP store
88x88x30mm (HxWxD)
