LightwaveRF Hand Held Remote Control for up to 16 devices with master (on/off) button  - White
Quicklinx: 8HD5WS00 Mfr#: JSJSLW100WH
See How LightwaveRF Can Transform Your Home Into a Smart Home!
The LightwaveRF Connect Handheld Remote Control has the ability to switch on-off or dim up-down any number of LightwaveRF Lighting, Heating and Power devices and can transmit up to 16 unique commands. It also offers mood lighting control and an All Off' feature at the touch of a button. LightwaveRF will transform the way you control your home.<br /> </p><ul><li>Controls any LightwaveRF Home Automation Lighting, Power and Heating Device</li><li>Turn your LightwaveRF Light Switches and Power Sockets 'All Off' at the touch of a button </li><li>Intelligent Lighting Control, Store and Recall mood' lighting settings, Save Energy
  • Transmits up to 16 unique LightwaveRF commands
  • Intuitive, easy setup and use
  • Spec
    • Wireless Type - LightwaveRF: 433.92MHz
    • Power - Battery: 3V CR2023 Lithium (included)
    • Fitting - Battery operated non-wired device
    • Operation - On-Off, Dim Up-Down
    LightwaveRF Connect Series LW100 - remote control - handheld - white
    Remote control handheld
    Power Source
    Wireless
    Frequency Band
    433.92 MHz
    White
    Power Source
    Wireless
    Frequency Band
    433.92 MHz
    Blue LED indicator
    CR2032
    Battery Included
    Lithium
    Voltage Provided
    3 V
    White
