L212 (Generation 2) Lighting Starter Kit
Beautifully designed smart dimmers to help you control your home lighting from wherever you are.
Begin your home automation adventure by using our stylish smart dimmer to control your lights. With a Link Plus and a 1 gang smart dimmer, you'll have everything you need to start controlling your lights, setting scenes, and making automations. This model incorporates all the great features from our Generation 1 products and adds Apple HomeKit compatibility, 2-way communication, built-in energy monitoring, and more! This dimmer is quick and easy to DIY install.
HomeKit Control
Lightwave’s remote control dimmer switch seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart lighting from your smartphone or tablet, from wherever you are.
Easy compatibility
A contemporary stainless steel finish houses an all-new 350W smart dimmer to ensure compatibility with the majority of current dimmable LED lamps.
Feature rich
Our second generation dimmer light switch offers soft-start illumination, 2-way switching as default, energy monitoring and multi-way wireless communication with other Lightwave dimmers.
Simple installation
Standard wiring configurations make the smart light dimmer switch easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
Control Lightwave devices
Link Plus compatible with Gen 1 & Gen 2 devices (excluding Gen 1 remotes and wire-free switches)
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
Easy compatibility
A contemporary stainless steel finish houses a 350W smart dimmer to ensure compatibility with the majority of current dimmable LED lamps. -
Feature rich
The second generation dimmer light switch offers soft-start illumination, 2-way switching as default, energy monitoring and multi-way wireless communication with other Lightwave dimmers. -
Simple installation
- LightwaveRF L212 - 2nd Generation - Lighting Starter Kit - home automation kit - white, stainless steel
- Product Type
- Home automation kit
- Functions
- Energy use monitor, light control
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Package Content
- Central controller, dimmer
- Connectivity
- Wireless
- White, stainless steel
- 2-year warranty
- Product Type
- Functions
- Package Content
- Connectivity Technology
- Wireless
- Platform
- Apple HomeKit
- Compatible Services
- IFTTT
- Nominal Voltage
- AC 230V
- Warranty
- 2-year warranty
- Dimensions & Weight Details
- Central controller: 10.1 cm x 3 cm x 10.1 cm x 218 g , Dimmer: 8.8 cm x 2.8 cm x 8.8 cm x 186 g
