Liebert PSI-XR 1500VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI-XR allows the unit to be configured as a self-standing tower or to be rack-mounted within a 2U space. It is available in four capacities.
- Liebert PSI-XR PS1500RT3 - UPS - 1350 Watt - 1500 VA
- UPS - external
- Rack Size
- 2U
- 28 kg
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 1350 Watt / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 5 min at full load
- Networking
- Ethernet 10/100
- Remote Management Protocol
- SNMP
- System Requirements
- Microsoft Windows 2000 / XP, Apple MacOS X 10.2 or later
- 44 cm x 49.1 cm x 8.8 cm
- 2 years warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 2U
- UPS Technology
- Line interactive
- Supported Battery Technology
- Lead Acid
- Input Voltage Range
- AC 165 - 300 V
- Frequency Provided
- 45 - 65 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 45 - 65 Hz
- Power Capacity
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 220 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Run Time (Up To)
- Recharge Time
- 5 hours
- Remote Management Interface
- Ethernet 10/100
- SNMP
- 1 x management (USB) - 4 pin USB Type B , 2 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x LAN
- Expansion Slots
- Expansion Slot
- Cables Included
- 2 x power cable - external , Serial cable - external - 1.8 m , USB cable - external - 1.8 m
- Rack Mounting Kit
- Included
- Audible alarm
- IEC 62040-2 class B, IEC 62040-1-1, RoHS, WEEE
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 90%
- Sound Emission
- 40 dBA
- 44 cm
- 49.1 cm
- 8.8 cm
- 28 kg
- Shipping Width
- 56 cm
- Shipping Depth
- 61.2 cm
- Shipping Height
- 22.8 cm
- Shipping Weight
- 32 kg
