Liebert PSI  2200VA 1980W 230V RACK/TOWER UPS
Quicklinx: 7GX2WS00 Mfr#: PS2200RT3-230
Liebert PSI 2200VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI allows the UPS to be configured as a self-standing tower or to be rack-mounted within a 2U space. It provides reliable power protection for servers, critical nodes, network workstations, large network peripherals, network routers, bridges, and other electronic equipment.
  • Efficient power management
    The Liebert PSI UPS features line interactive UPS technology, ensuring efficient power management and protection against power outages and fluctuations. Its sinewave output waveform ensures a smooth and consistent power supply to connected devices.
  • Rapid recharge capability
    Equipped with hot-swappable batteries that recharge in just 5 hr, the Liebert PSI UPS minimizes downtime, ensuring your operations are back up and running quickly after a power disruption.
  • Comprehensive connectivity
    This UPS offers a variety of connectivity options including RS-232 and USB interfaces, allowing for easy management and monitoring of the power supply system. The inclusion of an EPO (emergency power off) port adds an extra layer of safety in critical situations.
  • Designed for durability
    The Liebert PSI UPS comes with a robust plug-in module design and is compliant with RoHS standards, ensuring reliable performance in a range of environmental conditions, from 0°C to 40°C.
Liebert PSI PS2200RT3-230 - UPS - 1980 watt - 2200 VA
UPS - Power Factor Correction (PFC) - rack-mountable / external
Rack Size
2U
38.3 kg
Input Wiring
1-phase
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V ± 5%
Power Capacity
1980 watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid - 7.2 Ah
Battery Form Factor
Plug-in module
Batteries Qty
6
Run Time (Up To)
3 min at full load
RS-232, USB
Tower stand
44 cm x 65.7 cm x 8.8 cm
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 165 - 300 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
1980 watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
220 joules
Circuit Protection
Circuit breaker
Power Factor (PF)
0.9
Quantity
6
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
3 min at full load , 4 min at 90% load , 5 min at 80% load , 7 min at 70% load , 9 min at 60% load , 11 min at half load , 14 min at 40% load , 19 min at 30% load , 44 min at 20% load , 82 min at 10% load
Recharge Time
5 hours
Transfer Time
4 ms
Sealed
Remote Management Interface
RS-232, USB
1 x USB 2.0 - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Tower stand
USB cable - external , 2 x power cable - external
Rack Mounting Kit
Included
LED display, remote ON/OFF function, hot-swappable batteries, VRLA battery support, forced cooling
EN 61000-3-2, IEC 61000-3-2, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-6, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, IEC 62040-1-1, IEC 62040-2, RoHS, EN 62040-1-1, EN 62040-2
Software Included
Liebert MultiLink
0 - 90%
Sound Emission
45 dB
44 cm
65.7 cm
8.8 cm
38.3 kg
Shipping Width
56 cm
Shipping Depth
77.6 cm
Shipping Height
22.8 cm
Shipping Weight
38.3 kg
