Liebert PowerSure PSA 1500VA UPS System - 230V
Quicklinx: 7GXPWS00 Mfr#: PSA1500MT3-230U
Type: UPS
Power Rating: 900watt
£145.64 ex VAT
£174.76 inc VAT
Liebert PSA 1500VA is a compact line-interactive UPS that offers cost-effective, full featured power protection for small office computer and electronic equipment. Liebert PSA mixes unique features and extraordinary performance. Designed with simple controls for easy operation, it provides up to five minutes of back-up time at full load: more than enough time to save work in process and shut down your system.
  • Efficient power protection
    The Liebert PSA 1500MT UPS offers reliable power protection and battery backup, utilizing line interactive UPS technology to safeguard individual PCs against power surges and interruptions.
  • Comprehensive connectivity
    Equipped with 8 output connectors, including 2 surge-only protected and 6 battery-backed outlets, this UPS ensures a wide range of devices can be connected and protected simultaneously.
  • Enhanced environmental adaptability
    Designed to operate within a broad range of environmental conditions, the Liebert PSA 1500MT maintains performance with an operating humidity range of 0 - 90% and temperature range from 0°C to 40°C, ensuring reliability in diverse settings.
  • Intuitive management and diagnostics
    Features such as LED indicators and an audible alarm system provide immediate status updates on the UPS, while the USB interface allows for easy integration and management through a PC.
Liebert PSA 1500MT - UPS - 900 watt - 1500 VA
UPS - Power Factor Correction (PFC) - external
12.6 kg
Load Rating
Individual PC
Input Wiring
1-phase
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
900 watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
2 x power IEC 60320 C13 (surge) - 230 V , 6 x power IEC 60320 C13 - 230 V
Lead Acid - 9 Ah
Batteries Qty
2
Run Time (Up To)
12 min at half load
USB
14.7 cm x 36 cm x 23.4 cm
Load Rating
Individual PC
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
900 watt / 1500 VA
Dataline Surge Protection
Network - RJ-45 - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
570 joules
Circuit Protection
Circuit breaker
Power Factor (PF)
0.6
Quantity
2
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
12 min at half load
Recharge Time
6 hours
Transfer Time
6 ms
Sealed
Remote Management Interface
USB
1 x USB 2.0 - 4 pin USB Type B
3 x power cable - external , USB cable - external
Audible alarm, LED indicators, over current protection, VRLA battery support, overload protection
cUL, UL 1778, FCC Part 15 B, EN 62040-1-1, IEC 62040-1-1, RoHS, IP20
0 - 90%
14.7 cm
36 cm
23.4 cm
12.6 kg
Shipping Width
23.8 cm
Shipping Depth
43.2 cm
Shipping Height
35.2 cm
Shipping Weight
12.8 kg
Type: UPS
Brand: Liebert
