Liebert PowerSure PSA 1000VA UPS System - 230V
Quicklinx: 7GXLWS00 Mfr#: PSA1000MT3-230U
Type: UPS
Power Rating: 600Watt
£337.63 ex VAT
£405.15 inc VAT
Liebert PSA 1000VA is a compact line-interactive UPS that offers cost-effective, full featured power protection for small office computer and electronic equipment. Liebert PSA mixes unique features and extraordinary performance. Designed with simple controls for easy operation, it provides up to five minutes of back-up time at full load: more than enough time to save work in process and shut down your system.
  • Reliable power protection
    The Liebert PSA 1000MT UPS offers reliable power protection and battery backup, utilizing line interactive UPS technology to safeguard your equipment from power disturbances.
  • Efficient cooling
    Designed to operate efficiently across a wide temperature range, the Liebert PSA 1000MT ensures your equipment stays cool, even at a max operating temperature of 40°C.
  • Versatile connectivity
    With 8 output connectors and a frequency provided of 50/60 Hz, this UPS ensures a wide range of devices can be connected, offering flexibility in setup and use.
Liebert PSA 1000MT - UPS - 600 Watt - 1000 VA
UPS - Power Factor Correction (PFC) - external
9.5 kg
Load Rating
Individual PC
Input Wiring
1-phase
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
600 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
2 x power IEC 60320 C13 (surge) , 6 x power IEC 60320 C13
Lead Acid - 7 Ah
Batteries Qty
2
Run Time (Up To)
10 min at half load
USB
14.7 cm x 36 cm x 23.4 cm
Load Rating
Individual PC
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
600 Watt / 1000 VA
Dataline Surge Protection
Network - RJ-45 - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
570 Joules
Circuit Protection
Circuit breaker
Power Factor (PF)
0.6
Quantity
2
Lead Acid
Voltage Provided
12 V
7 Ah
Run Time (Up To)
10 min at half load
Recharge Time
6 hours
Transfer Time
6 ms
Sealed
Remote Management Interface
USB
1 x USB 2.0 - 4 pin USB Type B
3 x power cable - external , USB cable - external
Audible alarm, LED indicators, over current protection, overload protection, VRLA battery support
cUL, UL 1778, FCC Part 15 B, IEC 62040-1-1, RoHS, EN 62040-1-1, IP20, ISTA 1A
Software Included
Drivers & Utilities
0 - 90% (non-condensing)
14.7 cm
36 cm
23.4 cm
9.5 kg
Shipping Width
23.8 cm
Shipping Depth
43.2 cm
Shipping Height
35.2 cm
Shipping Weight
10.7 kg
Type: UPS
Brand: Liebert
