Liebert Liebert GXT2 Rack Slide Kit 18/32 Inch
Quicklinx: 7GXTWS00 Mfr#: RMKIT18-32
Hurry, only 1 left in stock!
£104.23 ex VAT
£125.07 inc VAT
Telescoping rails that mount to the sides of the rackmount UPS to facilitate installation into a rackmount enclosure. This kit is for use with all GXT2 and associated battery cabinets. Rack kits include hardware for mounting rack slide to rack frame, hardware for mounting rack slide to UPS is included with UPS.
  • Robust design
    Designed to support up to 90 kg, this rack mounting kit from Vertiv ensures your PC hardware is securely installed with reliability at its core.
  • Versatile compatibility
    The Liebert rack mounting kit is engineered to be compatible with PC systems, offering a seamless integration for your computing environment.
Liebert - rack mounting kit
Rack mounting kit
Silver
Liebert GXT4-10000RT230E, GXT4-1000RT230E, GXT4-1500RT230E, GXT4-2000RT230E, GXT4-240VBATTE, GXT4-3000RT230E, GXT4-48VBATTE, GXT4-5000RT230E, GXT4-6000RT230E, GXT4-700RT230E, GXT4-72VBATTE
Rack mounting kit
Silver
Weight Limit
90 kg
Product Type: Rack mounting kit
Brand: Liebert
