Liebert Intellislot Web Card-LB
Quicklinx: 556PWS00 Mfr#: IS-WEBCARD
For enhanced UPS communications and control, the Liebert IntelliSlot IS-WEBCARD delivers SNMP and web-management communications capability to your Liebert GXT unit. This feature will provide flexibility in how you monitor and control your UPS over the network. The card is also easily configurable to work in a standard SNMP implementation and with Liebert's MultiLink unattended shutdown software.
  • Enhanced connectivity
    With an RJ-45 connector for Ethernet 10Base-T/100Base-TX and a 9-pin D-Sub (DB-9) for RS-232, this Web Card ensures versatile connectivity options for a wide range of networking needs.
  • Robust security
    Featuring SSL encryption, the Liebert Intellislot Web Card provides a secure platform for managing your devices, ensuring your data remains protected.
  • Comprehensive network support
    Supports a variety of data link protocols including Ethernet, Fast Ethernet, and RS-232, alongside a data transfer rate of 100 Mbps, making it suitable for high-speed networking environments.
  • Efficient management
    Equipped with remote management protocols such as HTTP, HTTPS, SNMP 1, SNMP 2c, SNMP 3, and Telnet, this card allows for efficient and flexible management of your networked devices.
  • Reliable operation
    Designed to operate within a wide range of environmental parameters, including a humidity range of 10 - 90% (non-condensing) and temperatures from 0°C to 55°C, ensuring reliable performance under various conditions.
Liebert Intellislot Web Card - remote management adapter - Liebert IntelliSlot
Remote management adapter
Plug-in module
Interface (Bus) Type
Liebert IntelliSlot
7.6 cm x 13.4 cm x 3.8 cm
200 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, RS-232
Data Transfer Rate
100 Mbps
Liebert GXT3-1000MT120, GXT3-1000RT120, GXT3-1000RT230, GXT3-1500RT120, GXT3-1500RT230, GXT3-2000RT120, GXT3-2000RT230, GXT3-3000RT120, GXT3-3000RT208, GXT3-3000RT230, GXT3-500RT120, GXT3-700RT120, GXT3-700RT230
Plug-in module
Liebert IntelliSlot
Wired
Cabling Type
Ethernet, Fast Ethernet, RS-232
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS
Status Indicators
Power, link OK
DHCP support, BOOTP support, E-mail alert, firmware upgradable, SMS alert
1 x 100Base-TX - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x Liebert IntelliSlot
Encryption Algorithm
SSL
1.75 Watt
7.6 cm
13.4 cm
3.8 cm
200 g
55 °C
Resources
The following resources are available for the Liebert Intellislot Web Card-LB
