Liebert GXT3 5000VA (400W) Rack/Tower UPS
Quicklinx: 7GWYWS00 Mfr#: GXT3-5000RT230
The Liebert GXT3 is a compact, online uninterruptible power system (UPS) that continuously conditions and regulates its output voltage. The Liebert GXT3 is designed to supply microcomputers and other sensitive electronic equipment with clean sine wave input power.
Upon generation, AC power is clean and stable. However, during transmission and distribution it is subject to voltage sags, spikes and complete failure that may interrupt computer operations, cause data loss and damage equipment.
The Liebert GXT3 protects equipment from these disturbances. The Liebert GXT3 continuously charges its batteries from the mains, enabling it to supply power to connected loads, even when the mains fail. This section describes the UPS, its features, models, appearance and components, operating principles and operating mode.
Liebert GXT3-5000RT230 - UPS - 4 kW - 5000 VA
UPS - Power Factor Correction (PFC) - external
Rack Size
19" - 5U
60 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V
Power Capacity
4 kW / 5000 VA
Input Connectors
Hardwire
Output connectors
4 x power IEC 60320 C13 , 2 x power IEC 60320 C19 , 1 x hardwire
Lead Acid - 9 Ah
Batteries Qty
20
Run Time (Up To)
8 min at full load
USB
57 cm x 43 cm x 22 cm
Height (Rack Units)
5U
Rack Size
19"
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 176 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Hardwire
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
4 kW / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
20
Lead Acid
Voltage Provided
12 V
9 Ah
Run Time (Up To)
8 min at full load , 21.5 min at half load
Recharge Time
3 hours
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x Liebert IntelliSlot
Emergency power off, built-in maintenance bypass, internal bypass
EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, IEC 62040-1-1, EN 61000-4-5, IEC 62040-2
Software Included
Liebert MultiLink, Liebert Nform
0 - 95% (non-condensing)
Sound Emission
50 dBA
57 cm
43 cm
22 cm
60 kg
Shipping Width
74.5 cm
Shipping Depth
53 cm
Shipping Height
51.6 cm
Shipping Weight
71 kg
