Liebert GXT3-1500RT230 UPS 1350W + RAILKITPS3G-AEC rack moun
Quicklinx: 7GWSWS00 Mfr#: GXT3-1500RT230K
The Liebert GXT3 is a compact, online uninterruptible power system (UPS) that continuously conditions and regulates its output voltage. The Liebert GXT3 is designed to supply microcomputers and other sensitive electronic equipment with clean sine wave input power.
Upon generation, AC power is clean and stable. However, during transmission and distribution it is subject to voltage sags, spikes and complete failure that may interrupt computer operations, cause data loss and damage equipment.
The Liebert GXT3 protects equipment from these disturbances. The Liebert GXT3 continuously charges its batteries from the mains, enabling it to supply power to connected loads, even when the mains fail. This section describes the UPS, its features, models, appearance and components, operating principles and operating mode.
Liebert GXT3-1500RT230 - UPS - 1350 Watt - 1500 VA
UPS - Power Factor Correction (PFC) - external
Rack Size
2U
23.2 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
1350 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid - 7.2 Ah
Battery Form Factor
Plug-in module
Batteries Qty
4
Run Time (Up To)
4 min at full load
USB
Tower stand, rack mounting ears
43 cm x 49.7 cm x 8.5 cm
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 115 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
1350 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
4
Lead Acid
Voltage Provided
12 V
7.2 Ah
Run Time (Up To)
4 min at full load
Recharge Time
3 hours
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
USB cable - external - 2 m
Rack Mounting Kit
Included
Audible alarm
CISPR 22 Class A, EN 61000-3-2, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, IEC 62040-1-1, EN 61000-4-5, IEC 62040-2
Software Included
Liebert MultiLink
0 - 95%
Sound Emission
45 dBA
43 cm
49.7 cm
8.5 cm
23.2 kg
Shipping Width
57 cm
Shipping Depth
61.7 cm
Shipping Height
26.2 cm
Shipping Weight
26 kg
