LG XBOOM Go XG5QBK Portable Bluetooth Speaker
Quicklinx: HKK5WS00 Mfr#: XG5QBK.DGBRLLK
£108.33 ex VAT
£129.99 inc VAT
Play, Light and Boost.
Play the music, light up the mood and feel powerful sound with LG XBOOM Go.
Feel Powerful Sound with LG XBOOM Go
Experience LG XBOOM Go's remarkable sound that delivers deep bass and powerful sound together with LG’s latest sound technology.
New Track-Type Woofer Delivers Powerful Sound
Enjoy your favorite tracks with a track-type woofer. It produces a stunningly loud sound.
Music Comes to Life with the Sound of 20W
With powerful 20W outputs, you can rock to the beat and enjoy an elevated audio experience every time, from meditation to partying with friends.
Feel that Bass Even at Low Volume
The bass enhancement algorithm lets you hear and feel each distinct bass note, even when you turn the music down low.
Boost up Fun with Stronger Sound
One press of Sound Boost and you can widen the sound field and enjoy your music loudly.
Give Color to Every Music
With an expanded selection of 16 million colors, you can play every song alongside every color of the rainbow for an enriched music experience.
Sync Your Mood with Light Studio
Every moment has a color, sound. Experience the lighting and music that suits your mood of the day on the XBOOM App.
Loves Outdoor Adventures
LG XBOOM Go is ready to crank the outdoors. With IP67, it can withstand water and dust so you never have to worry about keeping the music going.
Keeps Music Powered Up to 18 Hours
Your music will keep going from morning to evening with LG XBOOM Go XG5’s 18-hour battery.
Answering Calls Hands-Free
LG XBOOM Go makes sure you get an incoming call while the music plays. It switches so you can chat hands-free.
Made With Recycled Plastic
UL has validated LG XBOOM Go as ECV (Environmental Claims Validation) products because some parts of the XBOOM Go body use recycled plastic-- We're taking a more eco-minded approach to portable Bluetooth speaker production.
  • Rugged design
    Built to withstand the elements, this speaker has an IP67 rating, making it both dustproof and waterproof. Ideal for outdoor adventures or poolside entertainment.
  • Dynamic lighting
    Enhance your listening experience with multi-colored LED speaker lights that sync to the beat of your music, creating an immersive audiovisual experience.
  • Versatile connectivity
    Featuring Bluetooth 5.1 for wireless streaming, along with USB Type-C and mini-phone 3.5 mm connections for wired options, this speaker ensures your music is always accessible.
  • Powerful audio performance
    With a continuous power output of 20 W and Sound Boost technology, enjoy high-quality, amplified sound that fills any space.
  • Convenient control
    App-controlled functionality allows for easy customization and control of your listening experience, directly from your smartphone.
LG XBOOM Go XG5QBK - speaker - for portable use - wireless
Speaker - for portable use
Protection
Dustproof, waterproof
Speaker Type
1-way - active
Continuous Power
20 Watt
Amplifier
Integrated
Bluetooth
Intelligent Assistant
Siri, Google Assistant - indirect
Sound Effects
Sound Boost, Deep Bass
Power Options
USB charging
Speaker battery rechargeable
22.2 cm x 8 cm x 8.3 cm
700 g
Environmental Standards
ENERGY STAR Qualified
Wireless Party Link
Light
Multi-colored LED speaker lights
Hands-Free Function
Protection
Enclosure Material
Recycled plastic
Speaker System
Speaker Type
1-way - active
Continuous Power
20 Watt
Multiroom
Amplifier
Integrated
Sound Effects
Bluetooth 5.1
Bluetooth Audio Codec
SBC, AAC
Compatible Software
LG XBOOM
Controls
Power on/off, volume, play/pause, next track, previous track, Bluetooth source
App-Controlled
Internet of Things (IoT)
Voice Control
Indirect
Speaker System Details
Driver Details
Speaker: woofer driver - 1.6" x 3.1" - Passive Radiator
Connector Type
USB-C (power only) (USB Type-C) , AUX input (mini-phone 3.5mm)
USB-C charging cable
UL, IP67, SGS
Supported Host Device OS
Android, iOS
Sustainability Information
ENERGY STAR Certified
Power Source
10 Watt
Options
USB charging
Rechargeable
Run Time (Up To)
18 hour(s)
Recharge Time
4 hour(s)
22.2 cm
8 cm
8.3 cm
700 g
Shipping Width
27.8 cm
Shipping Depth
12.8 cm
Shipping Height
12.4 cm
Shipping Weight
1.4 kg
