LG XBOOM 360 XO2 Bluetooth Speaker
Quicklinx: J3WHWS00 Mfr#: XO2TBK.CEUSLLK
Color your space with sound and light
Fill your space with sound and light, and connect to your mood.
Stay in the heart of your music
Surround yourself with your favorite music, no matter where you are. The 360° omnidirectional sound delivers a natural and consistently high-quality audio.
Smoother, clearer, wider
Your sound is faithful in every direction, even vertically. Crafted from premium materials like silk dome and fiberglass, the 2-way speaker system delivers clearer, richer sound. Feel extended highs, accurate mids and powerful bass.
Diffuse your vibes
Set the mood of your space. You can freely change the color of light to express your feelings. XO2T's open-heart structure is designed to illuminate the entire room in a full 360 degrees.
  • Powerful audio performance
    The LG XBOOM 360 is equipped with a 1" tweeter driver and a 3" subwoofer driver that provide a dynamic and balanced sound output suitable for both indoor and outdoor use.
  • Interactive lighting effects
    With vibrant RGB and mood lighting, the speaker transforms any setting, creating an immersive environment that complements the music.
  • Smart connectivity options
    Bluetooth 5.3 technology allows for quick and stable connections with devices, and the speaker is compatible with intelligent assistants like Siri and Google Assistant.
  • Durable and robust design
    The speaker's IP55 rating ensures durability against splashes, making it ideal for beach parties or outdoor use.
  • User-friendly controls
    With features like EQ mode selection, hands-free function, and the option to control via the LG XBOOM app, this speaker prioritizes empowerment and convenience.
LG XBOOM 360 XO2TBK - speaker - for portable use - wireless
Speaker - for portable use
Protection
Splash-resistant
Speaker Type
2-way - active
Continuous Power
20 Watt
Amplifier
Integrated
Bluetooth
Intelligent Assistant
Siri, Google Assistant - indirect
Sound Effects
Sound Boost
Speaker battery rechargeable
20.9 cm
Dimensions - Diameter
11.9 cm
0.9 kg
Multipoint, Wireless Party Link
Light
RGB lighting, Mood lighting
Hands-Free Function
Microphone
Protection
Splash-resistant
Speaker System
Speaker Type
2-way - active
Continuous Power
20 Watt
Amplifier
Integrated
Sound Effects
Sound Boost
Bluetooth 5.3
Bluetooth Audio Codec
SBC, AAC
Compatible Software
LG XBOOM
Controls
EQ mode selector, play/pause
App-Controlled
Internet of Things (IoT)
Communications Type
Product-to-product
Communications Technology
Bluetooth
Voice Control
Indirect
Speaker System Details
Driver Details
Speaker: tweeter driver - 1" , Speaker: subwoofer driver - 3"
Connector Type
USB (24 pin USB-C)
USB-C cable
IP55
Power Source
10 Watt
Rechargeable
Run Time (Up To)
15 hour(s)
Recharge Time
4 hour(s)
Diameter
11.9 cm
20.9 cm
0.9 kg
Shipping Width
16.5 cm
Shipping Depth
16.5 cm
Shipping Height
28.2 cm
Shipping Weight
1.5 kg
