LG US70TY Dolby Atmos 3.1.1 Channel Soundbar
Quicklinx: J3WBWS00 Mfr#: US70TY.AGBRLLK
11 left in stock
£207.50 ex VAT
£249.00 inc VAT
Express delivery Order within the next 10 hours for delivery tomorrow
Optimal audio excellence worthy of LG QNED
Complete the LG QNED experience with the soundbar that beautifully complements its design and sonic performance.
Blends beautifully with LG QNED
Appreciate the visual harmony of LG QNED and the all-new Crest Design LG Soundbar for refined interiors.
Soundscapes put you at their epicenter
The Center Up-firing Channel creates more lifelike sound, making voices clearer and on-screen action perfectly synced with the audio — no delays or stutters.
Alluring sound all around
Immerse yourself in the scene with the lifelike soundscapes of Dolby Atmos and DTS:X projected by a 400W 3.1.1ch surround sound system and subwoofer.
  • Powerful audio output
    With a total continuous power of 400 W and a 3.1.1-channel configuration, the LG US70TY sound bar system provides powerful and immersive sound that enhances your home theater experience.
  • Versatile connectivity options
    Equipped with multiple connection types including HDMI input, digital audio input, and USB, this sound bar allows for flexible integration with various devices, enabling seamless audio transmission.
  • Advanced sound modes
    Featuring sound modes such as Cinema, AI Sound Pro, and Game mode, the LG US70TY offers tailored audio experiences to suit different types of content, enhancing your enjoyment.
  • High-resolution audio support
    This sound bar supports high-resolution audio formats with maximum sampling rates of 96 kHz, ensuring clarity and detail in every sound, whether playing music or watching movies.
  • Smart app control
    The LG US70TY is app-controlled, providing convenient access to settings and features, allowing users to customize their audio experience from a smartphone or tablet.
LG US70TY - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 3.1.1-channel
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
400 Watt
Amplifier
Integrated
Bluetooth 5.1
Audio Formats
FLAC, WAV, OGG, MP3, AAC
Speaker System Details
1 x sound bar 180 Watt , 1 x subwoofer 220 Watt 3 Ohm
Speaker Details
Sound bar - front channel x 4 - 30 Watt - 10% THD - 6 Ohm - active , Sound bar - centre channel - 30 Watt - 10% THD - 6 Ohm - active , Sound bar - top centre channel - 30 Watt - 10% THD - 6 Ohm - active
Built-in Decoders
DTS Digital Surround, Dolby Digital, Dolby Atmos, DTS:X
Sound Effects
Clear Voice Pro, AI Sound Pro, Sport mode, Game mode, Cinema, Bass Blast, Bass Blast+
WOW interface, TV sound mode share
Speaker System
System Components
Speaker Type
Active
Continuous Power Details
RMS
Audio System Continuous Power (Total)
400 Watt
Maximum Bit Rate Supported
24 Kbps
Maximum Sampling Rate Supported
96 kHz
High-Resolution Audio
Amplifier
Integrated
Sound Effects
Audio Return Channel (ARC) Capability
Bluetooth 5.1
Bluetooth Audio Codec
SBC, AAC
Video Pass-Through
2160 (4K)
Built-in Decoders
Audio Formats
App-Controlled
Speakers Included
1 x sound bar - 180 Watt - wall-mountable / table-top , 1 x subwoofer - 220 Watt - 3 Ohm - wireless
Speaker Details
Connector Type
HDMI-eARC (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , HDMI input (19 pin HDMI Type A) , USB
Remote control, mounting bracket, HDMI cable
CEC
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Sound bar: 95 cm x 11.5 cm x 6.3 cm / 3 kg , Subwoofer: 20 cm x 28.5 cm x 37.7 cm / 5.7 kg
Shipping Weight
13.3 kg
5 °C
5 - 80% RH (non-condensing)
Brand: LG
Stock Status: While stocks last
Stock Status: Clearance
