LG UM88C 34" 3440x1440 5ms HDMI Display Port IPS Monitor
Quicklinx: C0MVWS00 Mfr#: 34UM88C
Perfect for multitasking and entertaining, the LG 21:9 UltraWide is always the right choice. A full range of 21:9 UltraWide monitors, both curved and flat, are available to meet your needs.
The 21:9 UltraWide QHD (3440 x 1440) display enables you to stretch the limits of screen real-estate. With the IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or RGB color code through a sRGB over 99% color space and IPS's accurate color expression. Since color calibration tests are conducted on the production line and the Hardware Calibration Ready with a built-in scaler to directly adjust the color setting, its color accuracy is guaranteed with tools for perfect color management.
  • 21:9 UltraWide rules
  • 21:9 UltraWide QHD on IPS display
  • Flawless color expression
  • Advanced tech design
    The adjustable stand with Height and Tilt function allows you to provide more comfortable working conditions.
  • USB 3.0 quick charge
    Charge the battery of a connected device quickly using the USB 3.0 port on the product.
  • The big convergence of FreeSync & 21:9 UltraWide QHD
    The FreeSync era has come. On the 34-inch 21:9 UltraWide QHD, you can experience the next level of gaming without any tearing and stuttering.
LG 34UM88C - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey), 14 ms (On/Off)
Colour Support
1.07 billion colours
Colour Gamut
99% Adobe RGB (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Voltage
AC 120/230 V
82.99 cm x 25.24 cm x 42.89 cm
8.4 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
79 kWh
Diagonal Size
34"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Mercury free, PBP, MaxxAudio, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Mega DFC, USB 3.0 Quick Charge
82.99 cm x 25.24 cm x 42.89 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x HDMI , Headphones , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Key lock
Stand
Input Voltage
AC 120/230 V
54 W
Power Consumption (Typical)
65 Watt
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows
Dimensions & Weight Details
With stand - width: 82.99 cm - depth: 25.24 cm - height: 42.89 cm - weight: 8.4 kg , Without stand - width: 82.99 cm - depth: 4.92 cm - height: 37.98 cm - weight: 6.3 kg
C0MV C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £17.37
C0MV C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.28
C0MV C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.62
