This 21:9 UltraWide QHD display offers visual comfort and ensures amazing viewing pleasure. There is no color shift or distortion of color at all. Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
21:9 UltraWide QHD
21:9 UltraWide QHD display offers visual comfort and ensures amazing viewing pleasure. There is no color shift or distortion of color at all. -
The beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair. -
Game mode
Game mode, consisting of FPS, RTS, and custom modes, provides a customized gaming experience that varies with genres. -
Fully geared with winning features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time. -
Flawless color expression
You are guaranteed an immersive artwork. Color calibration tests are conducted on the production line to ensure color accuracy.
- LG 34UC88 - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 79 kWh
- Power Consumption (On mode)
- 54 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey), 14 ms (On/Off)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Voltage
- AC 120/230 V
- 81.76 cm x 25.24 cm x 44.78 cm
- 8.3 kg
- FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0
- Display Type
- Energy Class
- Class B
- 79 kWh
- Diagonal Size
- 34"
- Curved Screen
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 3440 x 1440
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture in picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Color Weakness Mode, Dark Room mode, Mega DFC, USB 3.0 Quick Charge, 99% sRGB colour gamut
- 81.76 cm x 25.24 cm x 44.78 cm - with stand
- 8.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , DisplayPort , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Key lock
- Input Voltage
- AC 120/230 V
- 54 W
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Sleep
- 1.2 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows
- Dimensions & Weight Details
- With stand - width: 81.76 cm - depth: 25.24 cm - height: 44.78 cm - weight: 8.3 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.2 kg
