LG SK5R
4.1 ch High Res Audio Sound Bar
Key Features
DTS Virtual : X
High Resolution Audio
Wireless Surround Speakers
Adaptive Sound Control
Control with your TV Remote
Harmonious Design
DTS Virtual : X
The Champion of channel based audio. Advanced DSP decoding interprets audio signals and shoots virtual sound vertically and horizontally around you to create a full three dimensional sound experience. Get inside extraordinary audio today.
A new standard of sound quality. With advanced audio processing technology delivering sound of up to 24bit/92kHz quality you have some of the best components available for Hi-Res Audio. Now you can listen to studio standards of sound with lossless playback, experiencing a new level of audio that is true to the original.
Wireless Rear Speaker Kit
Surround your senses with sound. This Soundbar includes two additional rear speakers which when synced to an AV receiver enhance your audio solution to a 4.1 configuration. Create a surround sound system in your home, easily and wirelessly.
Action movies, dramas, sports, music and even the nightly news all have different audio profiles, so don't listen to them all the same way: Adaptive Sound Control identifies what's playing and automatically adjusts the sound mode to create the ideal audio experience.
LG Sound Bar comes with its own remote but it can also be controlled with your own TV remote. (TV remotes of LG, Sony, Philips, Sharp, Panasonic, Vizio, Toshiba and Samsung can control your LG Sound Bar.)
Harmonious Design
Its sleek modern edge design blends perfectly into any décor.
Promises a full, three-dimensional surround sound
Get an immersive cinema experience any time. With DTS Virtual: X, The LG Sound Bar SK5R always provides multi-dimensional sound in your home regardless of the content. You can enjoy a wider, higher, more immersive sound even from your favorite TV show or sports game. -
High resolution audio
Digital music has gone audiophile, with higher sampling rates and bit depth which can contribute to a more accurate, more enjoyable listening experience. This Hi-Res certified Sound Bar can play back lossless stereo audio at up to 96kHz/24-bit quality. -
Wireless surround speakers
LG Sound Bar SK5R includes wireless surround speakers, adding the premium cinema experience of dedicated rear channels, with wireless convenience. -
Action movies, dramas, sports, music and even the nightly news all have different audio profiles, so don't listen to them all the same way. Adaptive Sound Control identifies what's playing and automatically adjusts the sound mode to create the ideal audio experience. -
LG Sound Bar comes with its own remote but it can also be controlled with your own TV remote. -
Harmonious design
- LG SK5R - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 4.1-channel
- Media Content Source
- USB-host
- System Components
- 2 speakers, subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 480 Watt
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, LPCM, AAC +, OGG
- Speaker System Details
- 1 x sound bar 160 Watt 4 Ohm , 1 x subwoofer 200 Watt 3 Ohm , 2 x rear channel speaker 60 Watt 3 Ohm
- Built-in Decoders
- Dolby Digital, DTS Digital Surround, DTS Virtual:X
- Sound Effects
- Adaptive Sound Control (ASC), Bass Blast
- Power
- AC 120/230 V (50/60 Hz)
- Product Type
- USB-host
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 480 Watt
- Maximum Sampling Rate Supported
- 96 kHz
- High-Resolution Audio
- Sound Effects
- Bluetooth 4.0
- Built-in Decoders
- Audio Formats
- Speakers Included
- 1 x sound bar - 2-way - 160 Watt - 4 Ohm , 1 x subwoofer - 200 Watt - 3 Ohm - wireless , 2 x rear channel speaker - 60 Watt - 3 Ohm - wireless
- Driver Details
- Sound bar: 2 x tweeter driver , Sound bar: 2 x woofer driver
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 6"
- Driver Details (3rd speaker)
- Rear channel speaker: full-range driver - 2.5" - paper
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A)
- Included Accessories
- Remote control, wireless receiver / amplifier
- Voltage Required
- Dimensions (WxDxH) / Weight Details
- Sound bar: 89.1 cm x 8.78 cm x 5.75 cm / 2.35 kg , Subwoofer: 17.1 cm x 24.85 cm x 39.3 cm / 5.3 kg , Rear channel speaker: 8.8 cm x 8.1 cm x 12.2 cm / 1.74 kg
