LG SK5 2.1 Channel 360W Soundbar System
Quicklinx: DJ0YWS00 Mfr#: SK5
The LG SK5 always provides multi-dimensional sound in your home regardless of the content. You can enjoy a wider, higher, more immersive sound even from your favorite TV show or sports game.
  • High-resolution audio
    Digital music has gone audiophile, with higher sampling rates and bit depth which can contribute to a more accurate, more enjoyable listening experience. The SK5 can play back lossless stereo audio with incredible quality.
  • Adaptive sound control
    Action movies, dramas, sports, music and even the nightly news all have different audio profiles, so don't listen to them all the same way: adaptive sound control identifies what's playing and automatically adjusts the sound mode to create the ideal audio experience.
  • Harmonious design
    Its sleek modern edge design blends perfectly into any décor.
LG SK5 - sound bar system - wireless
Sound bar system - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
360 Watt
Bluetooth
Audio Formats
WAV, WMA, AAC, PCM, MP3, FLAC, AAC +, OGG
Speaker System Details
1 x sound bar 160 Watt 4 Ohm , 1 x subwoofer 200 Watt 3 Ohm
Built-in Decoders
Dolby Digital, DTS Digital Surround, DTS Virtual:X
Sound Effects
Adaptive Sound Control (ASC), Bass Blast
Power Options
Auto power off
USB-host
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
360 Watt
Maximum Sampling Rate Supported
96 kHz
High-Resolution Audio
Sound Effects
Bluetooth 4.0
Built-in Decoders
Audio Formats
Speakers Included
1 x sound bar - 2-way - 160 Watt - 4 Ohm - on-wall mounted , 1 x subwoofer - 200 Watt - 3 Ohm - wireless
Driver Details
Sound bar: 2 x tweeter driver , Sound bar: 2 x woofer driver
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 6"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , USB (4 PIN USB Type A)
Digital audio cable (optical), remote control, wall mounting bracket
55 Watt
Options
Auto power off
Dimensions (WxDxH) / Weight Details
Sound bar: 89 cm x 8.7 cm x 5.7 cm / 2.35 kg , Subwoofer: 17.1 cm x 24.75 cm x 39.2 cm / 5.3 kg
Shipping Width
98.4 cm
Shipping Depth
21.7 cm
Shipping Height
41.6 cm
Shipping Weight
9.83 kg
