The LG ultra-short throw projector delivers vivid imagery within an exceptionally short distance of the projection surface. Set it just 5 inches away to get 60 inches of bright, vivid viewing, or go farther to get images up to 100 inches. The PF1000U gives you a cinematic viewing experience in clear Full HD 1080p picture quality. That's a picture so large it will make your home cinema experience feel like you brought the theater home. The PF1000U's LED light source displays natural and rich colors.
Ultra-short throw projection
The LG ultra-short throw projector delivers vivid imagery within an exceptionally short distance of the projection surface. Set it just 5 inches away to get 60 inches of bright, vivid viewing, or go farther to get images up to 100 inches. -
Big vivid picture
The PF1000U gives you a cinematic viewing experience in clear Full HD 1080p picture quality. That's a picture so large it will make your home cinema experience feel like you brought the theater home. -
LED illumination
The PF1000U's LED light source displays natural and rich colors. -
Easy set up
The PF1000U sets up easily. Just set it on a flat surface a few inches from the wall, connect it to your video source and home audio, dim the lights and press play. No mounting brackets required. -
Wireless connectivity
Wirelessly screen-share content to the PF1000U using Wi-Fi with a smartphone or a tablet. -
HDMI connectivity
For even more viewing versatility, you can quickly connect the PF1000U to your game console, BluRay player, laptop or other devices using an HDMI cable. -
Bluetooth sound out
Wirelessly stream sound directly from the PF1000U projector to a Bluetooth compatible sound system like home audio speakers, headphones or portable speakers to pair big sound to the big viewing experience. -
Perfect image alignment
With the 4-corner keystone technology, the PF1000U allows for adjustment of each of the four corners of the image for ideal projection image alignment.
- LG MiniBeam PF1000U - DLP projector - ultra short-throw - portable - 3D - WiDi / Miracast Wi-Fi Display - titan black
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Titan black
- Built-in Devices
- Stereo speakers, TV tuner
- Brightness
- 1000 lumens
- Contrast Ratio
- 150000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Lens
- Ultra short-throw fixed lens
- Bulb type
- RGB LED
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM D/K, M-NTSC), Intel Wireless Display (WiDi) / Miracast Wi-Fi Display - DTV
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 100 Watt
- 13.1 cm x 30.9 cm x 12.8 cm
- 1.9 kg
- 3D Capable
- Built-in Devices
- Networking
- Bluetooth
- Enclosure Colour
- Titan black
Projector
- Brightness
- 1000 lumens
- Contrast Ratio
- 150000:1
- Image Size
- 152.4 cm - 254 cm
- Projection Distance
- 0.413 m - 0.686 m
- Throw Ratio
- 0.29:1
- Uniformity
- 80 %
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Bulb type
- RGB LED
- Bulb life cycle
- Controls & Adjustments
- Gamma correction, colour temperature, keystone correction, black level
- OSD Languages
- English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Greek, Turkish
- Auto Input Search, Closed Caption, MP3 playback, Noise Reduction, USB host function, Auto Vertical Keystone, Office Viewer, DOC files support, PPT files support, XLS files support, 4:3 aspect ratio support, Ultra Short Throw Technology, blank screen, Auto Power Off, Eco Mode, sleep timer, horizontal image flip, vertical image flip, Bluetooth Audio Support, instant on/off, Screen Share, Smart Mobile Link, 3D Optimizer, Picture Still
Lens
- Focus Type
- Manual
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Horizontal, vertical
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM D/K, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- Video Modes
- Digital Video Format
- DTV
- LAN and Wireless Image Transferring Protocols
- WiDi, Miracast
- Digital TV Tuner
- DVB-T2
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x digital audio output - TOSLINK , 1 x headphones - mini-phone stereo 3.5 mm , 1 x component video input - mini-phone stereo 3.5 mm , 1 x composite video/audio input - mini-phone stereo 3.5 mm , 1 x TV aerial input
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x A/V cable
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 100 Watt
- Power Consumption Stand by
- 0.5 Watt
- 13.1 cm
- 30.9 cm
- 12.8 cm
- 1.9 kg
- 0 °C
- 40 °C
- 0 - 80%
- Sound Emission
- 24 dBA
- Sound Emission (Economic Mode)
- 21 dBA
