Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
Protect your eyes and view in comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero. -
Preset customized options with just a click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse. -
Customize your workspace for multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen. -
Offers improved color vision to color weakness
- LG 22M38A - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 45% (CIE 1931)
- Input Connectors
- VGA
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 50.85 cm x 18.67 cm x 38.65 cm
- 2.4 kg
- Plug and Play, DDC/CI
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Colour Support
- Colour Gamut
- 45% (CIE 1931)
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- Picture in picture, split screen, Picture Mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Smart Energy Saving technology, My Display Preset, Color Weakness Mode, Mega DFC
- 50.85 cm x 18.67 cm x 38.65 cm - with stand
- 2.4 kg
- VGA
Mechanical
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Input Voltage
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 50.85 cm - depth: 18.67 cm - height: 38.65 cm - weight: 2.4 kg , Without stand - width: 50.85 cm - depth: 5.68 cm - height: 31.57 cm - weight: 2.1 kg
