LG LG 22MR410-B - LED monitor - Full HD (1080p) - 22"
Quicklinx: HK69WS00 Mfr#: 22MR410-B.AEKQ
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, VGA (HD-15)
More than 50 In Stock
£68.68 ex VAT
£82.41 inc VAT
Discover the LG 22MR410-B, a 22-inch LED-backlit LCD monitor designed to elevate your viewing and gaming experience. With its Full HD 1080p resolution and VA technology, it delivers crisp, clear images and wide viewing angles. The monitor's 99% sRGB color gamut ensures vibrant and accurate colors, making it perfect for both professional and leisure activities.
For gamers, the AMD FreeSync technology and a 100 Hz V-Sync rate at max resolution provide smooth gameplay without any tearing or stuttering. The 3-side virtually borderless display enhances your immersive experience, while features like Black Stabilizer give you an edge in dark scenes.
Not only is the LG 22MR410-B feature-packed, but it's also designed with your comfort in mind. Flicker Safe and Reader Mode reduce eye strain during long usage periods, and the tilt-adjustable stand allows for an optimal viewing angle. Additionally, its energy-efficient design and Class E energy label make it an eco-friendly choice for your home or office.
  • Immersive viewing experience
    The 22-inch LG 22MR410-B monitor, featuring a 3-side virtually borderless display and a 99% sRGB color gamut, offers an immersive viewing experience with vibrant, accurate colors.
  • Seamless gameplay
    Equipped with AMD FreeSync technology and a 100 Hz V-Sync rate, this monitor ensures smooth gameplay without any tearing or stuttering.
  • Comfortable viewing
    Flicker Safe and Reader Mode reduce eye strain during long usage periods, while the tilt-adjustable stand allows for an optimal viewing angle, enhancing overall comfort.
LED-backlit LCD monitor - 22"
Energy Class
Class E
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.2537 mm
Brightness
250 cd/m²
Response Time
5 ms (grey-to-grey)
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Display Type
Energy Class
Class E
Diagonal Size
22"
Viewable Size
21.45"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2537 mm
Brightness
250 cd/m²
Colour Gamut
99% sRGB (CIE 1931)
Response Time
5 ms (grey-to-grey)
Backlight Technology
LED backlight
3-side virtually borderless display, Reader Mode, Flicker Safe, Black Stabilizer
HDMI , VGA (HD-15)
Mechanical
Tilt
Security Slot Type
Kensington security slot
15 kWh/1000h
Included Software
LG On-Screen Control
Diagonal Size: 22in
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
