LG G5 SE Sim Free Android 32GB Titan Grey
Quicklinx: CRNHWS00 Mfr#: LGH840.AGBRTN
  • microSDHC
  • Android
Beauty in the palm of your hands. Metal and glass smoothly float together uninterrupted, without an antenna slit. The sleek design of iconic simplicity. Unparalleled comfort and fit, that you must hold to believe.
LG G5 SE H840 - titan - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
H840
Display
LCD display - 2560 x 1440 pixels - 5.3" - 554 ppi - IPS Quantum
FM radio
Qualcomm Snapdragon 652 1.8 GHz (8-core) - 64-bit
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 2 TB
Operating System
Android 6.0.1 (Marshmallow)
Main Camera
16 Megapixel - f/1.8 - focus: automatic laser auto focus: - laser focus
Second Camera
8 Megapixel - wide-angle lens - f/2.4
Front Camera
8 Megapixel - wide-angle lens - f/2.0
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Titan
73.9 mm x 7.7 mm x 149.4 mm
159 g
0.981 W/kg (head) , 1.44 W/kg (body) , 1.585 W/kg (head (simultaneous)) , 1.809 W/kg (body (simultaneous))
Smartphone
H840
Touch
Integrated Components
FM radio
73.9 mm
7.7 mm
149.4 mm
159 g
Body Colour
Titan
Body Material
Metal
SAR Value
1.44 W/kg (body), 0.981 W/kg (head), 1.809 W/kg (body) (simultaneous), 1.585 W/kg (head) (simultaneous)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
Wireless Interface
IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Phone Features
Phone Functions
Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
Sensors
Ambient light sensor, proximity sensor, digital compass, motion sensor
Security Devices
Fingerprint reader
Additional Features
Radio Data Service (RDS), DLNA Certified, sharing media via DLNA, QuickMemo function, Wi-Fi Miracast, infrared remote control, KnockON, Capture Plus function, Knock Code function, notification LED, Alarm Clock, modular design
Clock Speed
1.8 GHz
Processor Core Qty
8-core
64-bit Architecture
RAM
3 GB
Internal Memory Capacity
32 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 2 TB
Front Camera
Sensor Resolution
8 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.0
Camera Modes
Gesture Shot, Auto Shot
Virtual Flash
Main Camera
Sensor Resolution
16 Megapixel
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Laser Auto Focus
Digital Zoom
8x
Camera Modes
Panorama, Time-lapse mode, manual mode, Auto mode
HDR Mode
Auto HDR mode
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p), 3840 x 2160 (4K), Slo-mo video 1280 x 720 (720p) at 120 fps
Touch & Shoot, Multi View recording
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Wide-angle lens
Lens Aperture
F/2.4
Display
LCD display
IPS Quantum
Diagonal Size
5.3"
Display Resolution
2560 x 1440 pixels
Display Format
QHD
Pixel Density
554 ppi
Max Brightness
850 cd/m²
Colour Depth
16.7 million colours
Always-on display
Connector Type
Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
2800 mAh
Power adapter, USB-C cable
