This LG IPS monitor ensures and awesome picture quality that provides clear images and vivid colors from any angle for your viewing pleasure.
ArcLine stand
The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake. -
Sleek design
The remarkable reduction of depth with body frame adds sophisticated ambience for your place. -
Protect your eyes and view in comfort
Did you know that your eyes are affected by flickers on the monitor while you may not have seen them? Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero. -
Immerse yourself in the game
The Black Stabilizer allows you to have better visibility, even in dark scenes. -
Customize your workspace for multitasking
Screen split divides the display into multiple sections for different tasks by resizing the windows on the screen. You can work on the main screen while watching a video in a smaller window floating on the screen. -
Improved color vision to color weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
- LG 24MP58VQ - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1976)
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 55.05 cm x 18.68 cm x 41.9 cm
- 3.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0
- Display Type
- Energy Class
- Class B
- 36 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1976)
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Picture in picture, HDCP, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Color Weakness Mode, Mega DFC
- Black
- 55.05 cm x 18.68 cm x 41.9 cm - with stand
- 3.2 kg
- VGA , HDMI , DVI-D , Headphones
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- Key lock
- Input Voltage
- 25 W
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg , Without stand - width: 55.05 cm - depth: 8.55 cm - height: 33.21 cm - weight: 2.8 kg
Sustainability Information
- ENERGY STAR Certified
